× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
WNDAP350 FW 2.1.2 WebInterface Bug with Safari
goi
Guide
Guide
and another one:
using Safari 5.1.x the option Wireless on-off is missing!
Regards
goi
Message 1 of 6
jmizoguchi
Virtuoso
Re: WNDAP350 FW 2.1.2 WebInterface Bug with Safari
If you are using Mac, use Firefox if works and also bug report support directly and not forum
My.netgear.com
Message 2 of 6
goi
Guide
Guide
Using Mozilla doesn't work either. Using the development mode of Safari you may set the responded user agent to IE, than it works.
It seems the developer has limited the frame to IE?
regards
goi
Message 3 of 6
goi
Guide
Guide
It does not work with Mozilla either.
A possible workaround is, using the development mode of Safari and set the user agent respond to IE.
It seems the developer has restricted the frame to IE?
regards
goi
Message 4 of 6
jmizoguchi
Virtuoso
You need to disable java sript on Firefox
Message 5 of 6
jmizoguchi
Virtuoso
Same as below
http://forum1.netgear.com/showthread.php?t=26851
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 5779 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
