- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
WiFi extender Failure
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried using a netgear wifi extender last year, but it was such a failure as the signal continually dropped out making it useless.
Anyway, this year I am adding a wired extension to my network, using a LAN switch and cables (obviously!). That is so I can use other PCs in areas where the WiFi does not reach. However, I still want to use WiFi on phones etc in thos areas so I thought I'd give the netgear range extender another try.
I plugged it into the LAN switch (assuming that, if I was only extending wifi from THAT point, the signal may not drop off so easilly) and it lit up to go, but here's the issue: When the extender is plugged into the LAN switch, the wired connection from the switch to other PCs drops out.
Anyone got any bright ideas?
Obviously I've considered the whole smashing the netgear extender with a lump hammer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: WiFi extender Failure
Hi RobRamshackle,
Which WiFi extender are you using? and which router is connected to it?
Please connect an ethernet cord from your switch to your WiFi extender and set it up as "Access Point" not "Extender".
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks, I can see now that this extender (WN3000RP) shouldn't be connected by LAN and only works via WiFi as an extender, not an access point. I'm going to open another thread as my main problem is not this now. Thanks for your help anyway
