× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
WiFi extender setup AC1750
Bellancott
Follower
New unit now connected to router, but no internet access. Must have missed a step somewhere..... Anyone with a solution would be appreciated.. 4 led on front - 2 on, 1 off, 1 on (from left hand side). Thanks in advance.
Message 1 of 3
Guru
Re: WiFi extender setup AC1750
Did you set it up using the push button WPS option?
If so, factory reset the extender  and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Message 2 of 3
Imyourangel0104
Once you get the netgear extender powered on, go to settings and connect to netgear_EXT. It will show no connection.  Open safari type in the IP address of the extender. It will open up a page, it will have set up extender, follow the instructions it will be really easy from there. Then you can move it to where you need the boost the most, give it a few minutes to start back up.
good luck.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2997 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
