Orbi WiFi 7 RBE973
Reply
WiFi extender to VOIP
onealc09
Follower
I just bought an extender to connect my VOIP office phone.  I have had issues with the phone randomly rebooting and I am trying to trouble shoot and see if it is because I configured the extender incorrectly, a faulty phone, or I should have the phone plugged into the modem instead.  The phone works sometimes and at other times, it will reboot and completely disconnect from the network.  Please advise.  Thanks!
Model: EX3700|N600 WiFi Range Extender
Message 1 of 2
DexterJB
NETGEAR Moderator
Re: WiFi extender to VOIP
Hi @onealc09,
Welcome to the community!
Best way to proceed is to isolate the issue. You can remove the extender from the picture and connect the VOIP straight to your router/modem-router and check if the issue will persist. Also, it may be a hardware issue on the VOIP part. Try another power adapter with the same specs and/or another power outlet.
Dexter
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3546 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
