× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wifi extender EX 6400
kfr8319
Follower
Hi!
Just purchased Wifi Ext Model EX6400........How to I find Security Key?
Model: EX6400v2|AC1900 WiFi Mesh Extender Essentials Edition
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Wifi extender EX 6400
When you set the router up it uses the wireless password from the router you connected it to unless you specify a different one.
DarrenM
Message 2 of 4
Twg
I tried that and it wants internet security key and I can not find that
Message 3 of 4
Christian_R
NETGEAR Employee Retired
Hello Twg,
You may want to factory reset the extender by pressing on the small black button using a pin for 15+ seconds then join the NETGEAR_EXT wifi network using a phone or laptop. After you connect to the NETGEAR_EXT network with your phone or laptop, browse to www.mywifiext.net and follow the setup instructions.
Christian
Message 4 of 4
Discussion stats
  • 3 replies
  • 928 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
