- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi extender doing nothing but “boosting”, whatever that is
- Mark as New
- Bookmark
- Subscribe
- Permalink
My AC1750 dual band wifi extender was working fine. But i bought a new one to get better coverage. So i pulled the existing one out to move it. Upon plugging it in somewhere else, all its done is the on/off button just slowly flashes green. WTF?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi extender doing nothing but “boosting”, whatever that is
Have you tried factory resetting it and then doing a full reinstall?
Push and hold reset for 7-15 seconds while its powered on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes mate, have tried that. Have also left it unplugged overnight. No success. AU$200 down the drain after only a couple of months it seems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are any of the other led's lighting up?
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you, but sorry. I have no idea how to even do stepone of those instructions. I dont have an ethernet cable either.
- Mark as New
- Bookmark
- Subscribe
- Permalink
There's a video that walks you through it.
And a ethernet cable is pretty easy to aquire at a store.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you. I might trybit later. In the meantime, i needed i ternet, so had to buy another one. Not particularly happy.
