- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wifi range extender N300
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ho acquistato wifi range extender N300 per amplificare il segnale wifi in tutta la casa.
Peccato che il led client non si sia mai acceso e non consente il log alla rete nuova_EXT
Consigli?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wifi range extender N300
Factory reset the extender. Push and hold reset while its powered on for 7-15 seconds.
Then re-run the installation and use the installation wizard and not using wps. Wps gets coded different between different manufacturer's and can create issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Stee wrote:
Done....but it doesn’t log the network
this didn't help. it didn't explain what you did. "log the network" can be taken many different ways.
Please be precise in what steps you did, where the errors are, and whats going on. I'm not there to see so I can't help without details
- Mark as New
- Bookmark
- Subscribe
- Permalink
<br>I find my homenetwork <br>Insert the correct psw...but i can’t log <br>( ACL is disable in my router) ...so i can’t continue <br>
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Stee wrote:
Ook...sorry <br>So...step By step<br>I swich on the extender<br>Open the network netgear_ext<br>Log to the browser mywifiext
What router are you connecting to?
What do you mean by "acl is disabled in my router"?
What wireless security are you using on your router?
If you have any special characters/spaces in the router's ssid/password, remove them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Acl is the acces control list....so the extender should be free to connect.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Stee wrote:
I have a modem/router adsl2+wifi wpa psk.------Not a router mode. If a mechanic asks what model car you have saying "its got an engine, 4 tires, and a steering wheel". Its not helpful. What manufacturer and model do you have?
Acl is the acces control list....so the extender should be free to connect.--------supposedly.
You also put you're running wpa-psk. its an outdated wireless security. you should be running wpa2.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes...it’s not the top
