- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Will WN2000RPT or WN3000RP Connect to Aircard 815S?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Will either one of these extenders connect to the AT&T Aircard 815S? I need a wired connection from my aircard which is my only internet source.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Will WN2000RPT or WN3000RP Connect to Aircard 815S?
They should both work. The WN2000RPT gives you more ethernet ports.
But their wifi speeds are slower than the Aircard (N300 instead of 802.11ac). That might not matter (depending on the LTE throughput you are getting). But if you don't want the wifi link to be the bottleneck, you might consider getting an 802.11ac extender. For instance an EX6100 is well matched to your Aircard wifi. An EX6200 might be another option if you need more ethernet ports.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the quick reply back. I will check into the EX6100.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
