- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
X6S EX8000 Webinterface nicht erreichbar
- Mark as New
- Bookmark
- Subscribe
- Permalink
HALLO,
HABE EINEN X6S GEBRAUCHT GEKAUFT UND ÜBER WPS EINGERICHTET .
ES FUNKTIONIERT ALLES WUNDERBAR AUCH ÜBER DIE APP.
ABER WENN ICH MICH ÜBER DAS WEBINTERFACE AUF DEN REPEATER ANMELDEN MÖCHTE (Erstanmeldung) KANN ICH DAS NICHT.
ALLE BROWSER AUSPROBIERT UND AUCH MIT LAN KABEL.
DAS NEUE ADMIN PASSWORT UND DIE BEIDEN SICHERHEITSFRAGEN KANN ICH EINGEBEN DANN IST SCHLUSS.
DANN STEHT IM FENSTER HABEN SIE EIN WENIG GEDULD UND DER KREIS
DREHT SICH BIS IN ALLE EWIGKEIT .
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
did you factory reset it?
Push and hold reset for 7-15 seconds while powered on.
that'll get you back to the defaults.
default login: admin
default password: password
All lower case.
then you can reset the login password
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
All lower case.
