Reply
ex7500 needs to be reset every 2-3 days to be able to roam to it again
rockscully
Tutor
The extender is paired with a r7800 netgear router. I have selected  'one wifi name' and "smart connect" . I disabled the 'Sync configuration with Netgear router" because by doing so i can use a different 2.4 Ghz channel than the router. The extender communicates with the router on channet 149 and the extender talks to clients on channel 1 and 48. Firmware version is the latest 74. Problem is that after 2 or 3 days i have to unplug the extender  so that my devices can roam to it again. When it becomes defective, i still can access it's ui by entering it's ip adress and the status screen seems to show that everything is normal but when i get out of range of the router, i cannot roam to the extender.
I have tried everything like resetting to factory, restarting, unplugging but the same problem comes back every 2 or 3 days. Bad news is that other people seems to have similar issue on Amazon comments
Anybody else having this problem and or have a solution to that?
Model: EX7500|AC2200 Nighthawk X4S Tri Band WiFi Mesh Extender
Message 1 of 6
rockscully
Tutor
Re: ex7500 needs to be reset every 2-3 days to be able to roam to it again
Message 2 of 6
rockscully
Tutor
Replying to myself. Seems that this problem is like 3 years old and Netgear never did anything to correct it . See also this post :
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/EX7500-Range-extender-drops-connecti...
What a shame. Will throw this piece of junk to garbage  and never buy Netgear again
Message 3 of 6
olympos1625
NETGEAR Moderator
Hi rockscully,
Thank you for reaching out. We are sorry to hear about your experience with the extender. We would like to endorse you to NETGEAR Level 2 support team for callback. Please provide the following information:
Name:
Email:
Phone:
Preferred schedule (atleast 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
Message 4 of 6
rockscully
Tutor
Actually testing firmware 1.0.1.76 that's been available since oct 22. No problems so far. Will report in a couple of weeks.
Message 5 of 6
lisahaley000
Thanks for sharing information.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 206 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
