Orbi WiFi 7 RBE973
Reply
extender to extender connectivity
Blcampbell1968
Follower
using multiple extenders:   once an extender is programmed to connect to a wifi router, if i move it too far from the router, will it connect to another extender to get a signal and push that signal out ?
Message 1 of 2
Guru
Re: extender to extender connectivity
 Its usually not recommended to daisy chain extenders. Especially the single/dual band ones. Reason why is each extender drops the throughput of what they receive by 50%. So daisy chaining them drops throughput significantly plus it increases latency.
Maybe going over what you're attempting to do in detail will better help us to help you.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 530 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
