× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
need help to set up wifi
lportillo89
Follower
how do i get to the set up page for my wifi extender where you get to choose your wifw to set up on your new wifi range extender
Model: EX3110|AC750 Dual Band WiFi Range Extender
Message 1 of 2
Guru
Re: need help to set up wifi
did you try looking at the install guide or manual? they both show how.
https://www.netgear.com/support/product/EX3110.aspx
or if using that doesn't work, tell us how its failing? or where in the process it isn't working.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 245 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
