Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
nighthawk extender disconnecting
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-09-04
09:42 AM
2017-09-04
09:42 AM
setup extender and it worked great bit every couple of days devices connected to the 2.4 connection are dropped. when I try to connect to it via phone I get message that ip address not found or something to that effect. if I unplug device and plug in it works again. netgear support of no help..spent hours on phone with them. any ideas. I have done initial setup her multiple times as well. if I do not get resolution I am returning and buying another brand.
Message 1 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-09-07
02:59 PM
2017-09-07
02:59 PM
Re: nighthawk extender disconnecting
Hello quida
Have you updated to the latest firmware? you may also want to assign a static IP in your router to the extender.
DarrenM
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-09-07
05:00 PM
2017-09-07
05:00 PM
great timing. just got off phone w netgear again. firmware was up to date. they assigned static channel to extender wifi and changes channel for 5ghz. 2.4ghz had channel as auto. will see in a couple of days if it is fixed.
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-09-13
06:34 PM
2017-09-13
06:34 PM
Problem is back. how do I assign static up address? and if I do this can i change channels on router and / or extender or is it now set permanently?
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2017-09-15
04:03 PM
2017-09-15
04:03 PM
Hello quida
You will have to assign the static Ip in your router and the channel should be the same one your router is using.
DarrenM
Message 5 of 5
