Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
set time limits for users?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-14
07:42 PM
2013-12-14
07:42 PM
Fiance' has a 12 year old who will not stop using his iPad, even when his mother tells him no .. he will jump on when his mother sleeping....
is there a way to set the router so specific users can no longer connect after a certain hour?
I have a WNDR4300
Thanks
I have a WNDR4300
Thanks
Message 1 of 3
Retired_Member
Not applicable
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-15
07:02 AM
2013-12-15
07:02 AM
Re: set time limits for users?
Yes, first you must use address reservations for that device. This is required to setup the next part. go to advanced, setup, Lan Setup,under address reservations click ADD, if Ipad is connected it should show up, just select it. then click Apply use this IP in next step
Go to advanced, security, Blocked services, under services blocking, check by schedule, which you will have to create a schedule in the schedule menu.
next click add, service type select all, filter services for, click only this IP
enter IP address for IPad then apply.
This should do it. I don't have this router but I think the options for this setup should be available.
Message 2 of 3
- Mark as New
- Bookmark
- Subscribe
- Permalink
2013-12-15
12:02 PM
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
