- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
wifi extender not visible on windows 10
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can anyone advise, my new wifi extender is not being detected on my windows 10 machine, i have successfully connected on my linux and android devices but it is not showing up on my windows 10 device
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: wifi extender not visible on windows 10
Are you seeing other wifi networks on the Windows 10 system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes all other networks are still visible, not sure if there is anything that needs enabling on the network adapter
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the PC is within range of the WiFi then it should be seeing the network. Are you using the normal Windows facilities to connect?
- Mark as New
- Bookmark
- Subscribe
- Permalink
yes i am using the standard windows connection, i can connect it to the same router that is feeding the extender but not the externders signal itself
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you had a dual-band extender and were using FastLane, I'd have suggested making sure that your extender's client-facing network was 2.4G (guessing that the PC didn't support 5G). But the EX2700 is single band.
It sounds like a windows issue, since the other devices are seeing it. You could try a Windows WiFi Analyzer tool, and see if that finds it. If it does, you can try manually entering the network name and passphrase.
- Mark as New
- Bookmark
- Subscribe
- Permalink
thats what i was thinking, was looking ot post here as if there might have been any tweaks i need to make on my apaters end, i have tried adding manually to no avail but i will look inot a wifi analizer tool
- Mark as New
- Bookmark
- Subscribe
- Permalink
When you figure it out, please post back with the solution!
- Mark as New
- Bookmark
- Subscribe
- Permalink
if anyone has any other suggestions feel free to post
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Kevelstone,
1. What is the firmware version of the extender?
2. Have you tried changing the wireless channel?
3. Have you tried re-installing/rolling back the drivers for the adapter?
Dexter
Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @Kevelstone,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
