× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
wifi network not found
Robbart
I was running my wn1000rp for a couple of month without any problems.
But since today the repeater is not able to connect to my network. I tried to do a factory reset and wanted to configure it again but the device found a lot of wifi networks but not mine. I also tried to type in thee SSID manually but it is not able to connect.
Can you please help?
Robbart
Message 1 of 4
Robbart
Re: wifi network not found
I am very disapointed that nobody was able to help me for such a long time. I was exspecting a better service from netgear....
I recently found a solution for myself.
Message 2 of 4
CDesautels
I'm in the same boat Robbart. Were you ever able to connect to your default network?
Message 3 of 4
Robbart
i was able to connect to my default network after setting the wifi channels at my router from auto to static (in my case channel 6). the repeater seams to be unable to work with channels 12 and 13.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 10168 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
