Kdlatsha's avatar
Kdlatsha
N300 wireless router blue light not on
My router is model WNR2000, and the blue light to confirm wireless internet will not come on. The top two lights are green and my computer has no wireless internet because the blue light is off. Can anyone offer a solution to this? Thank you.
  • Thank you, Elaine.  Apparently, there was a setting on my computer that was not allowing the blue light to turn on, and the issue is now resolved.  Thank you for your reply.
    Kathy
    • Kdlatsha's avatar
      Kdlatsha
      Kathy
      • ElaineM's avatar
        ElaineM
        NETGEAR Employee Retired
        Can you share what kind of setting is that in order for others to benefit from it too?
