Reply
Problem connecting new vizio to wndr3700
I have tried several times to connect a new vizio XVT553SV tv to my WNDR3700. I keep getting "unable to connect" when I try to connect.
I even went through the process with Vizio tech support. They suggest disabling Mac filtering
Any suggestions? How do I disable Mac Filtering on the WNDR3700?
Appreciate the help.
sjmoors
Re: Problem connecting new vizio to wndr3700
By default it is disabled but you can go ahead and check:
Go to routerlogin.com
login username: "admin" and password: "password"
click on the Wireless Settings under Advance
Click the wireless card access list button
Turn access control on must not be checked
If thats not the issue, can you give us clue about your network setup.
your XVT553SV tv to the WNDR3700, is it connected wired or wireless?
Luminary
Mac filtering is not enabled at default so if you are only one setup the router and did not use other devices with Mac address to seup in the router , you did not enable it
I would look the wireless setting you are using.
2.4ghz/54Mbps + 5ghz wireless mode and WPA, WPA2 encryption
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
sjmoors
My guess is the problem is your firmware. If you can get your hands on .75 I would suggest that.
Novice
What type of wireless protection are you using? Do you have other computers connected to the router?
I am trying to connect the TV to Router via wireless.
I have had a laptop, wii, and nintendo DS connected at various times.
While in set up on TV...I have tried to connect to both 2.4 and 5 ghz. I have them set at WPA-PSK [TKIP] + WPA2-PSK [AES]. The TV will show them as options...after input of password, the TV indicates "unable to connect".
I tried to set up a guest network with no password...no luck.
I can see the MAC address when I look at attached devises - wireless...but it isn't connected.
Luminary
Have you experiment with WPA or WPA2 instead of WPA+WPA2?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
You have to set the static ip for the TV
In the network settings of the TV:
IP MANUAL
IP 192.168.1.150
Subnet: 255.255.255.0
Default Gateway: 192.268.1.1
DNS: 192.168.1.1
Set the TV up like this then click on the test and see if it connects.
Charlie C
Yes...tried the following with Vizio Tech Support:
WPA-PSK [TKIP]
WPA2-PSK [AES]
There was a question whether the TV could connect WPA2
Unfortunately, no luck.
SJMoors
Luminary
have you try CC999's suggestion?
using static IP.. I had that in mind but hoping different encryption may fix it.
ex.
IP 192.168.1.150
Default Gateway: 192.168.1.1
DNS: 192.168.1.1
you want to login the router and go to LAN setup and adjust the DHCP range
ex. follow above IP
DHCP range 192.168.1.2~ 192.168.149
you want to use static IP outside of DHCP is the idea.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
It looks as though that this is a good fix. So who is at fault here the Wndr3700 or the Vizio TV? I noticed the TV worked fine with my old router...
Netgear WPN824N with Vizio XVT 42 with VIA
Eureka - Thank you folks - I did the exact same as below... under manual settings i entered the following.....
IP 192.168.1.150
...but for the DNS settings in the Vizio, I got the two settings from the following:
In the Netgear router, from the Router Status page (under Internet Port) Get the primary and backup DNS settings from the two DOMAIN NAME SERVER addresses. Eureka. I spent two days fiddling with this crap. Thank you all who contributed to this thread.
Does this get your wireless working as well? I put in a static IP as above and now my ethernet connection finally works, but it still will not connect wireless. Thoughts?
It has to do with your password. For some reason if you use WPA or WPA2 Vizio TVs don't like long passwords or any any spaces in them. I had a really long password key I used and couldn't get it to connect either. I shortened it to about 10 characters without spaces and am now able to connect it via the 5GHz WPA band.
Thanks I will try it!
Will this ip work for the wndr200-v3?
Luminary
Will not make any difference what model it is.
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Whew! Finally got it working.
Thanks
LaVetta
Luminary
enjoy it. Smiley Happy
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
After spending an hour on this today, figured it out. In a nutshell, Vizio SmartTVs only support WiFi encryption WPA-PSK(TKIP).....nothing else.
On my NetGear router, I initially only had a security option that included both WPA-PSK(TKIP) and WPA-PSK(AES). Having both combined confused the Vizio TV. After poking around my Netgear interface, I enabled the Guest WiFi network and voila, the security options noted above were split out into separately-selectable options. I then selected WPA-PSK(TKIP) and was able to get the so-called Smart TV to connect and retain the connection in-between power cycles. Problem solved.
Discussion Stats
  • 19 replies
  • 20648 views
  • 0 kudos
  • 11 in conversation
Top Contributors
