Orbi WiFi 7 RBE973
Reply
VDSL Modem DM200: NAT Loopback not Working
13eastie
Star
I've just "upgraded" from an N600 to a DM200 to support my new VDSL connection.
My hope had been that the configuration would be practically identical to my previous setup.
I've enabled NAT and port-forwarding in the same way as previously, but I'm struck by how I cannot reach anything on my local network using my external IP address.  In fact, I cannot even reach the management interface.
I'd be very grateful if someone could confirm whether the DM200 supports NAT loopback, and, if so, how to activate (and test) it?
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: VDSL Modem DM200: NAT Loopback not Working
Hello 13eastie
You may need to make the DM200 in modem only mode if you are using that setting on your router.
DarrenM
Message 2 of 3
13eastie
Star
Hi DarenM
Thanks for the reply.
My hope had been to use the DM200 as a router, but it does not seem to support NAT Loopback.  This was how I was previously using my DGND3700.
In fact the only way I can get the loopback to work is to use the DM200 in modem only mode and then continue to use my old router to provide the LAN functionality I need.
It would be nicer to have just the one device and this seems a pretty simple fuction to have omitted in the DM200.
Message 3 of 3
Discussion stats
  • 2 replies
  • 4975 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
