AC1900
4 TopicsReadycloud not working properly
Hey all! So I have my USB hard drive connected to my R7000 and set up a ready cloud account. It shows my USB hard drive connected to it but when I click browse to view the files it doesn't show them at all in the web browser. It just flips me back to the R7000 icon instead of showing me a directory listing of what is on my USB hard drive. I checked to see if it works on the apple mobile app and I can browse all the files on my USB hard drive perfectly fine. Is anyone else having this issue? Thanks!8.8KViews0likes9CommentsR7000 Firmware Version 1.0.4.28 supports ReadyCLOUD
Nighthawk has you covered even when you're away from home with NETGEAR genie® remote access and ReadyCLOUD® you can manage your network and have access to a secure personal cloud anytime, anywhere. NETGEAR released new firmware for the Nighthawk R7000 router that allows you to plug in a USB drive to the router and use ReadyCLOUD to access files from anywhere, even from your smartphone. Download the new firmware onto your R7000 router today, attach a USB drive, and login to the router interface to get started with ReadyCLOUD. How to get started with ReadyCLOUD and Nighthawk R7000 here. What is ReadyCLOUD? PickMe4Beta NETGEAR Employee13KViews1like2Commentsr7000 and readycloud
Anyone know when this feature is comming? The new firmware released today supports remote connection through netgenie, bit I have ready that readycloud is coming. On my readyshare tab on my router it says to setup readycloud go to Tue website, but no option on the router itself to enable it.11KViews0likes9CommentsReadyCloud seems not to be Ready...
Hi there, I was excited to check out the ReadyCloud feature included in the latest firmware update (1.0.4.28). However, it is - at best - half-baked. The Netgear ReadyCLOUD seems to be where you configure access to your networked files. After registering your external drive it takes a while before your folders become visible (perhaps the index is copied over to the ReadyCLOUD server?). Hereafter you will be able to navigate folders/files. It would seem we cannot share folder access (read and/or write access) only download of individual files (a right-click on a file will allow you to 'E-mail as a Link'). What I need is to allow streaming access to my movies as well as access to my calibre2opds version of our Calibre library. Under 'Manage' appears two categories for 'Users' and 'Shared Links'. I suppose that when you email a link, receivers will appear in the latter. But how does one define 'Users'? Through apps (e.g. the Android version of ReadyCLOUD) streaming should be possible. I've tried to stream a movie but it was very jerky... The ReadyCLOUD server for me is always very slow to respond.10KViews0likes4Comments
