Engage gateway
2 TopicsThe current IGMP Querier does not match the planned IGMP Querier.
Hello, I have a network of 43 switches (M4250, M4350), without a Core, in a non conventional wiring configuration (not a star, not a daisy chain, just a mix) where I chosen the switch in the middle of it as Querier. After a few months, another one is acting as Quierer. I setted up the whole network with Engage and the devices are up to date. In Engage>Site Settings>IGMP Quierer I have a yellow mark on the selected switch (that is not acting as Quierer) the following message: The current IGMP Querier does not match the planned IGMP Querier. Is this already happen to anyone here? Thank you so much312Views1like1CommentNetgear Engage - Offline simulator
Hi All, I am undertaking the Netgear AV training. It is very heavily based around Engage which is good to know. However it seems that Engage has no 'offline' simulator to allow people without access to any actual switches to really learn and understand this software. Is there a method to run a virtual offline switch (or set of switches) and configure them to play with the profiles etc? If not it sort of makes the training somewhat redundant. Cheers Cal938Views1like1Comment
