Firmware Update
1 TopicVPN Setting
I'd like to see VPN Setting update in next firmware update that allows users to setup VPN with other VPN clients. While current instructions do allow for Smart DNS and shows how to create a VPN connection, it lacks today's needs. Having VPN support setting eliminates the need to run VPN on each device by allowing all connections to flow through router as one connection. Most services limit up to 3 connections at once. Having this support on my R8500 would totally eliminate the connections limit. Please consider supporting this with next firmware!24KViews15likes2Comments
