General App Feedback
13 TopicsInsight Topology Incorrect
One of my clients has two GS724TPv3 Switches. One switch (Cedar) has 9 ports connected, but the Topology only shows 6. The summary page shows that there are 9 ports connected. The other switch (Elm) shows 4 ports connected in the Topology as does the Summary Page. However, I use another tool, Auvik, for mapping and it shows a 5th port in use. Why the inconsistencies? Suggestion: Having a pictorial view of the switch and the connected ports would be very useful. Then if it could show the connection speed and any information about the device connected to the port. Finally the ability to disable/enable a port.489Views0likes2CommentsHow to Create a VLAN with Insight Management #Tutorial #Video
Creating a VLAN with your Insight Managed Smart Cloud Switch is easy from the Insight Management App. For the detailed tutorial visit the NETGEAR Insight Knowlegebase. Here's how to create a new VLAN in Insight Management 1. Open your Insight App 2. Tap on a switch in your network 3. Tap “VLANs in use” 4. Press the plus sign on top right of screen 5. Tap the type of network you want to create 6. Create your VLAN name and ID 7. Tap Save
Solved4.5KViews0likes1CommentWhat feautures would i / you like to have for the App/Cloudmanagement
Hey! as i understood there's lots of new feautures to come in 2018 within Insight. however i would like to start this thread to give an overview what i would like to have / see in future. maybe this can help out the dev team to priorise development according to the community needs and maybe even bring in some new ideas/feautures. would be great to have the community answer here kinda a request for feautures.... i've been playing arround for the past 3y with Cisco Meraki. their cloud solution is the top of the mount everest. now i rock netgear (WAC505) - i'm hoping netgear can catch up and become a good solution in future. feautures i'm missing / i'd like to see detailed traffic analytics / protocols and ability to see an overview what end device is consuming what / how much guest access (confirmed in another thread) ability to generate QR Codes / Pincodes -> facebook already implemented, great changelog on FW upgrade etc -> better visibility, easyier usage place access points/switches/devices on a map (google map) heat map scan frequencies and see what AP's are on what channels -> be able to choos another frequencies/channels in dense areas live data analytics (maybe in dashboard?) disable Lights on AP's trough App/Dashboard would be great if other users can add their wished here btw is there any chance to participate as beta user? BR8.1KViews5likes6CommentsCase Studies: Real Small Business Using Insight Management #Webinar #Video
NETGEAR Insight has Market-Leading functionalities with its Mobile First Solution. Network Discovery Simplified Setup and Installation Remote Monitoring Complete Ongoing Management Insight Managment: Your Network. Anytime. Anywhere. Unified remote network visibility and control with NETGEAR Insight management solution
6.5KViews0likes0CommentsNETGEAR Insight - Learn how Cloud-Managed Technology Can Work For your Business #VideoWebinar
Get an overview of Insight as well as details on new feature release for the Insight solution. NETGEAR Insight is a Cloud-based management platform that enables easy setup and configuration of NETGEAR Insight Managed Access Points, Switches and ReadyNAS devices. If you have questions or comments about NETGEAR Insight? Did you deploy an insight solution? We would love to hear from you. Please visit the NETGEAR Insight forum for more discussion or post your feedback.
6.3KViews0likes0CommentsInsight Management Web Portal Coming February 2018 #NETGEARatCES
A CES Innovation Award honoree, NETGEAR Insight management solution delivers unified remote monitoring and management for NETGEAR switches, wireless access points and ReadyNAS storage Currently available as a mobile app, the remote setup, monitoring and management features of the Insight™ management solution will also become available in mid-February through the new NETGEAR Insight Cloud web portal, providing the benefit of a larger display screen for a single-pane view of all devices and locations. As an honoree in the 2018 CES Innovation Awards competition for excellence in design and engineering, the NETGEAR Insight management solution is a progressive way to instantly discover, configure, and continuously monitor and manage your network. Designed for easy remote management of NETGEAR Smart Cloud Wireless Access Points, Smart Cloud switches and ReadyNAS Network Storage, Insight will now also provide support for the Orbi™ Pro Tri-band WiFi System for small businesses as of the update in mid-February. “NETGEAR Insight Managed devices have the lowest Total Cost of Ownership (TCO) of any remote/cloud manageable networking devices in the industry,” Richard Jonker, vice president of product line management for SMB products at NETGEAR, affirmed. “Businesses benefit from plug-and-play setup and management without the cost of an additional network management device or contracted IT service. There is no complex software, or on-premise cloud server to purchase and maintain and there are no exorbitant long-term licensing fees.” Watch this forum and the NETGEAR Insight page for more updates on Insight Managed products.3.4KViews0likes2CommentsInsight Management App and Access Control
Hi, Not sure how many of you use Access Control Lists (Allow Mode) with your configurations. I have recently added three WAC 510 APs to my configuration. Prior to that I just used a Netgear Nighthawk X6 R8000 for all my Wifi needs. Being somewhat obsessive about things, I have been using Access Control for all of the devices that connect to my router. That ACL is still in effect now, even though I have all but one wireless devices now connected to the APs. Although I'm not sure why I'm so obsessive about this (another topic), I would like to transition my Access Control from the router to the APs. I am managing those APs using the Insight Management App. I haven't been able to find any way to batch input allowed MAC addresses for the APs. There was a way, although with some bugs, when I was managing the APs locally via a web browser. Is there a batch method, or do I have to painfully enter the MAC addresses one at a time for each AP via the app?2.7KViews0likes1CommentA Message to Insight 2.x customers from the NETGEAR Insight Team!
Hi Everyone, Greetings from NETGEAR. As a follow up to our earlier communication regarding upgrading from Insight 2.0/2.x to our new remote access, cloud-based Insight solution, we want to remind you that at the end of this year we’ll be ending support for Insight 2.0/2.x. We encourage you to upgrade to Insight 3.1 - our new cloud-based Insight - as soon as possible. Migrating will give you the opportunity to enjoy the many advantages of the Insight cloud platform as well as the features in Insight 3.1 managing a broader range of devices – access points, switches, and storage. Here are links to the Apple App Store and Google Play store to upgrade. Apple iOS Google Android As the year comes to a close, we want to take the opportunity to thank you for continuing support for NETGEAR and to wish you the very best for 2018. Thank you, The NETGEAR Insight Team What do I need to know about the transition to Insight 3.0?2.4KViews0likes0Comments
