Genie 3.1.12
4 TopicsBug genie 3.1.12 android network name change text field inactive for first rightmost character
On the name change field in the network map device dialog, unable to tap first character on the right to gain field focus. Seems like the right of the text field is outside of a screen's active view. If you click on the second character or any character to yhe left you can get focus into the text field. Suggestion is to increase the screen boarder my one character width.3.3KViews0likes3Comments
