IP camera
3 TopicsRBS50 How to extend to a shed
Hi Have an Orbi RBK50 and RBS50 and need to connect a wired IP Camera by ethernet to an extender of some sort. The Camera is in a remote shed (25m away from the Orbi Satellite 40m from the Orbi Router) on a different power ring so cant use a powerline extender. I am using a Netgear extender at the moment but it keeps dropping out. When it works it works well but its not reliable as part of my CCTV system. Could someone advise the best product (extender) to use with the Orbi.C3700-100NAS is blocking ip Camera. I cannot see the ip address at all and do not know mac address
Normally, I have an issue setting up a new ip camera, because the router blocks the new ip address immediately. When the router blocks it I am unable to see the ip address at all, not even in the blocked attached devices. With the other cameras I have setup I was given the mac address (located on the camera or manual) and able to manually add it to LAN. This camera I do not have access to the mac address without being connected to it. Since my router is not even showing it attached (not even in blocked attached devices) I am at a loss of what to do. Can anyone walk me through a way to add the camera, please? Thanks in advance!!2.2KViews0likes2Comments
