Kentboyjohn's avatar
Kentboyjohn
RBS50 How to extend to a shed
Hi Have an Orbi RBK50 and RBS50 and need to connect a wired IP Camera by ethernet to an extender of some sort. The Camera is in a remote shed (25m away from the Orbi Satellite 40m from the Orbi Router) on a different power ring so cant use a powerline extender. I am using a Netgear extender at the moment but it keeps dropping out. When it works it works well but its not reliable as part of my CCTV system. Could someone advise the best product (extender) to use with the Orbi.
    • Kentboyjohn's avatar
      Kentboyjohn
      Hi and thank you for your response. I saw this on a US site but couldnt see its availability in the UK. Does this have an Ethernet port I can plug the IP camera into as its NOT WiFi?
