M4100-D12G
2 TopicsM4100-D12G temperature
Hi, I've M4100-D12G switch and have a question about System temperature. Switch is inside rack cabinet (4U) and System temperature is 47-52C. Cabinet is located in one of my office room. Is this temperature normal? Switch is hot (I had warranty replacement for a new one and the same results). I have M4100 24-ports or 48-ports or 24ports M5300 switches and they have lower temp - 27 to 40C. Yes I know they have fans... but I think temperature M4100-D12G is to high. Or am I wrong? :)2.6KViews0likes3CommentsM4100-D12G vlan 1 half duplex
I am in the process of setting up a new M4100-D12G switch. This is my first time configuring a Netgear switch so hopefull this is not a PEBCAK issue. VLAN 1 is configured for routing and for unknown reasons is running at 10mb half-duplex. I have created other VLAN interfaces with the same result. How do I configure the VLAN routed interfaces for 1G full-duplex. (M4100-D12G) #show version Switch: 1 System Description............................. M4100-D12G ProSafe 12-port Gigabit L2+ Intelligent Edge Desktop Managed Switch, 10.0.2.13, B1.0.1.1 Machine Model.................................. M4100-D12G Serial Number.................................. 0000000000000 Burned In MAC Address.......................... AA:BB:CC:DD:EE:FF Software Version............................... 10.0.2.13 Bootcode Version............................... B1.0.1.1 Supported Java Plugin Version.................. 1.6 Current Time................................... Oct 27 12:35:19 2015 (UTC-4:00) Current SNTP Sync Status....................... Success (M4100-D12G) #show port status vlan 1 Media STP Physical Physical Link Loop Partner Flow Intf Type Mode Mode Status Status Status Control ------ ----------- ------ ---------- ---------- -------- -------- ------------ vlan 1 10TX - 10 Half 10T Half Up Off3.1KViews0likes1Comment
