chfascik's avatar
May 05, 2016
M4100-D12G temperature
Hi,
I've M4100-D12G switch and have a question about System temperature. Switch is inside rack cabinet (4U) and System temperature is 47-52C. Cabinet is located in one of my office room. Is this temperature normal? Switch is hot (I had warranty replacement for a new one and the same results). I have M4100 24-ports or 48-ports or 24ports M5300 switches and they have lower temp - 27 to 40C. Yes I know they have fans... but I think temperature M4100-D12G is to high. Or am I wrong? :)
  • JohnRo's avatar
    JohnRo
    NETGEAR Employee Retired
    Hello chfascik,
    Welcome to the community!
    I would say it is a little hot but not to the extent of being alarming. Make sure that the temperature of the environment is 0 degrees to 50 degrees Celcius. Check if all of the fans are active as well, monitor the switch and see if the temperature increases.
    Thanks,
    • chfascik's avatar
      chfascik
      Tutor
      JohnRo - thanks for reply.
      M4100-D12G doesn't have fan so it can't be cool down by air. I tried made same rack mode and add dedicated fans to rack case. So now it's quit well. Temperature is 40-45C.
      Thanks for help.
  • JohnRo's avatar
    JohnRo
    Hi chfascik,
    No worries. :) Please update the post so other would see your response. Also, please mark any of the post replies as "Accept as Solution", this will help other users when using search.
    Thank you and have a great day!
    JohnRo
ProSupport for Business
