tammtamm
Oct 01, 2019Aspirant
Weerd msg console m4100-d12g
Hi,
On a netgear m4100-d12g I'm seeing the following when the device is starting up:
"Linking libproc_libs.so to /lib/libproc_libs.so
Invalid image name -"
I don't understand where 'Invalid image name' is comming from?
This msg is not present on an identical switch.
Any help is welcome.
Reposting this here in the proper forum! :)
RMA accepted for this device, thanks for the help in here and to the Netgear representative who has confirmed the RMA (as the ticket is already closed, I can't thank him for his help).
- JohnC_VNETGEAR Employee Retired
Hi tammtamm,
Welcome to our community! :)
May I know where are you seeing this? Is it from the console/ telnet/ GUI? Do you still have access to the web admin page? If yes, please try to re-install the firmware or update it to the latest firmware version.
You may download it here.
John
NETGEAR Community Team
- tammtammAspirant
Hi there,
Thanks for your answer.
I'm seeing this in the console, before asking here, I already tried to upgrade the FW but to no avail.
An other thing that I'm seeing is that I'm not able to boot on the backup image (image2 in my case):
User:admin
Password:
(M4100-D12G) >enable(M4100-D12G) #clear config
Are you sure you want to clear the configuration? (y/n)y
Clearing configuration. Please wait for login prompt.
(Unit 1)>User:admin
Password:
(M4100-D12G) >enable(M4100-D12G) #boot system image2
Activating image image2 ..(M4100-D12G) #show bootvar
Image Descriptions
image1 : test
image2 :
Images currently available on Flash---- ---------- ---------- ----------------- -----------------
unit image1 image2 current-active next-active
---- ---------- ---------- ----------------- -----------------1 10.0.2.30 10.0.2.30 image1 image2
(M4100-D12G) #reload
The system has unsaved changes.
Would you like to save them now? (y/n) yConfig file 'startup-config' created successfully .
Configuration Saved!
Are you sure you would like to reset the system? (y/n) y
Reference platform resetting ...syncing filesystems....This may take a few moments
/mnt/application
Rebooting system!
The system is going down NOW!
Sent SIGKILL to all processes
Requesting system reboot
Initializing Arena.
Initializing PCI. [normal]
PCI[0]: Initializing host
PCI[1]: Disabled
Initializing Devices.Loader:stk Filesys:raw Dev:flash2.stk1 File: Options:(null)
Loading: STK image is 12473348 bytes, CRC 0x24C9
3613652 bytes
Starting program at 0x80005170
Using the default image = /dev/mtd2
Checking for application
Exploding tgz file to RAM.../mnt/applicationStarting operational code application...
Rel 10, Ver 0, Maint Lev 2, Bld No 30
<10> Jan 1 00:00:31 0.0.0.0-1 General[46401964]: bootos.c(186) 3 %% Event(0xaaaaaaaa)
started!(Unit 1)>
Applying Global configuration, please wait ...
Applying Interface configuration, please wait ...
User:admin
Password:
(M4100-D12G) >enable(M4100-D12G) #show bootvar
Image Descriptions
image1 : test
image2 :
---- ---------- ---------- ----------------- -----------------1 10.0.2.30 10.0.2.30 image1 image1
(M4100-D12G) #
