tammtamm
Oct 01, 2019Aspirant
Weerd msg console m4100-d12g
Hi, On a netgear m4100-d12g I'm seeing the following when the device is starting up: "Linking libproc_libs.so to /lib/libproc_libs.so Invalid image name -" I don't understand where 'Invalid image...
- Oct 10, 2019
RMA accepted for this device, thanks for the help in here and to the Netgear representative who has confirmed the RMA (as the ticket is already closed, I can't thank him for his help).
tammtamm
Oct 09, 2019Aspirant
Thanks for bearing with me, hopefully the below will answer your question?:
User:admin
Password:
(M4100-D12G) >enable
(M4100-D12G) #clear config
Are you sure you want to clear the configuration? (y/n)y
Clearing configuration. Please wait for login prompt.
(Unit 1)>
User:admin
Password:******
User:admin
Password:
(M4100-D12G) #reload
The system has unsaved changes.
Would you like to save them now? (y/n) y
Config file 'startup-config' created successfully .
Configuration Saved!
Are you sure you would like to reset the system? (y/n) y
Reference platform resetting ...
syncing filesystems....This may take a few moments
/mnt/application
Rebooting system!
The system is going down NOW!
Sent SIGKILL to all processes
Requesting system reboot
qqqqq
Initializing Arena.
Initializing PCI. [normal]
PCI[0]: Initializing host
PCI[1]: Disabled
Initializing Devices.
Loader:stk Filesys:raw Dev:flash2.stk1 File: Options:(null)
Loading: STK image is 12473348 bytes, CRC 0x24C9
3613652 bytes
Starting program at 0x80005170
Using the default image = /dev/mtd2
Checking for applicationq
Boot Menu
Options available
1 - Start operational code
2 - Change baud rate
5 - Load new operational code using USB
6 - Display operational code Vital Product Data
7 - File system directory listing
8 - Update boot code
9 - Delete backup image
10 - Reset the system
11 - Restore configuration to factory defaults (delete config files)
12 - Activate Backup Image
13 - Password Recovery Procedure
14 - Reformat the file system
15 - Upload a file through XMODEM
16 - Download a file through XMODEM
17 - Start Diagnostics Application
Q - Quit from operational code Startup
Select option : 9
Erasing /dev/dev
mtd0
mtd1
mtd2
mtd3
mtd4
mtd5
mtd6. Please wait..
Erase finished
Boot Menu
Options available
Select option : 16
Select Mode of Transfer (Press X/Y/Z for XMODEM/YMODEM/ZMODEM) []:z
Do you want to continue? Press(Y/N): y
Ready to receive file via ZMODEM
Please start ZMODEM sender before the receiver times out
rz waiting to receive.**B0100000023be50
Copy to image1 or image2 chioce(1 or 2): 2
Copying the file. Please wait..
done.
Critical components modified -- System Reboot Recommended!
Reboot? (Y/N): y
Rebooting...
Rebooting system!
Sent SIGTERM to all processes
Initializing Arena.
PCI[1]: Disabled
3613652 bytes
Boot Menu
Options available
Select option : 12
Image /dev/dev mtd0 mtd1 mtd2 mtd3 mtd4 mtd5 mtd6 activated.
/dev/dev
mtd0
mtd1
mtd2
mtd3
mtd4
mtd5
mtd6 activated -- system reboot recommended!
Reboot? (Y/N): y
Rebooting...
Rebooting system!
Sent SIGKILL to
Initializing Arena.
PCI[1]: Disabled
3613652 bytes
Exploding tgz file to RAM.../mnt/application
Starting operational code application...
Rel 10, Ver 0, Maint Lev 2, Bld No 30
<10> Jan 1 00:00:32 0.0.0.0-1 General[46401964]: bootos.c(186) 3 %% Event(0xaaaaaaaa)
started!
(Unit 1)>
Applying Global configuration, please wait ...
Applying Interface configuration, please wait ...
User:admin
Password:
(M4100-D12G) #show bootvar
Image Descriptions
image1 : test
image2 :
Images currently available on Flash
unit image1 image2 current-active next-active
1 10.0.2.30 10.0.2.30 image1 image1
(M4100-D12G) #
The error message 'Invalid image name -' is still there nor am I able to boot on image2.
Am I missing something?
tammtamm
Oct 10, 2019Aspirant
