tammtamm
Oct 01, 2019Aspirant
Weerd msg console m4100-d12g
Hi, On a netgear m4100-d12g I'm seeing the following when the device is starting up: "Linking libproc_libs.so to /lib/libproc_libs.so Invalid image name -" I don't understand where 'Invalid image...
- Oct 10, 2019
RMA accepted for this device, thanks for the help in here and to the Netgear representative who has confirmed the RMA (as the ticket is already closed, I can't thank him for his help).
JohnC_V
Oct 03, 2019NETGEAR Employee Retired
Hi tammtamm,
Welcome to our community! :)
May I know where are you seeing this? Is it from the console/ telnet/ GUI? Do you still have access to the web admin page? If yes, please try to re-install the firmware or update it to the latest firmware version.
You may download it here.
John
NETGEAR Community Team
tammtamm
Oct 04, 2019Aspirant
Hi there,
Thanks for your answer.
I'm seeing this in the console, before asking here, I already tried to upgrade the FW but to no avail.
An other thing that I'm seeing is that I'm not able to boot on the backup image (image2 in my case):
User:admin
Password:
(M4100-D12G) >enable
(M4100-D12G) #clear config
Are you sure you want to clear the configuration? (y/n)y
Clearing configuration. Please wait for login prompt.
(Unit 1)>
User:admin
Password:
(M4100-D12G) #boot system image2
Activating image image2 ..
(M4100-D12G) #show bootvar
Image Descriptions
image1 : test
image2 :
Images currently available on Flash
unit image1 image2 current-active next-active
1 10.0.2.30 10.0.2.30 image1 image2
(M4100-D12G) #reload
The system has unsaved changes.
Would you like to save them now? (y/n) y
Config file 'startup-config' created successfully .
Configuration Saved!
Are you sure you would like to reset the system? (y/n) y
Reference platform resetting ...
syncing filesystems....This may take a few moments
/mnt/application
Rebooting system!
The system is going down NOW!
Sent SIGKILL to all processes
Requesting system reboot
Initializing Arena.
Initializing PCI. [normal]
PCI[0]: Initializing host
PCI[1]: Disabled
Initializing Devices.
Loader:stk Filesys:raw Dev:flash2.stk1 File: Options:(null)
Loading: STK image is 12473348 bytes, CRC 0x24C9
3613652 bytes
Starting program at 0x80005170
Using the default image = /dev/mtd2
Checking for application
Exploding tgz file to RAM.../mnt/application
Starting operational code application...
Rel 10, Ver 0, Maint Lev 2, Bld No 30
<10> Jan 1 00:00:31 0.0.0.0-1 General[46401964]: bootos.c(186) 3 %% Event(0xaaaaaaaa)
started!
(Unit 1)>
Applying Global configuration, please wait ...
Applying Interface configuration, please wait ...
User:admin
Password:
Image Descriptions
image1 : test
image2 :
1 10.0.2.30 10.0.2.30 image1 image1
(M4100-D12G) #
- JohnC_VOct 09, 2019NETGEAR Employee Retired
Were you able to press "q" while it boots up so that we can push the firmware image 2 on the boot menu? I believe that this is also covered with lifetime chat support.
You may open a ticket here.
John
- tammtammOct 09, 2019Aspirant
Thanks for bearing with me, hopefully the below will answer your question?:
User:admin
Password:
(M4100-D12G) >enable(M4100-D12G) #clear config
(Unit 1)>User:admin
Password:******User:admin
Password:
(M4100-D12G) >enable(M4100-D12G) #reload
Would you like to save them now? (y/n) yConfig file 'startup-config' created successfully .
Reference platform resetting ...syncing filesystems....This may take a few moments
/mnt/application
Rebooting system!
qqqqqInitializing Arena.
PCI[1]: Disabled
Initializing Devices.Loader:stk Filesys:raw Dev:flash2.stk1 File: Options:(null)
3613652 bytes
Checking for applicationqBoot Menu
Options available
1 - Start operational code
2 - Change baud rate
5 - Load new operational code using USB
6 - Display operational code Vital Product Data
7 - File system directory listing
8 - Update boot code
9 - Delete backup image
10 - Reset the system
11 - Restore configuration to factory defaults (delete config files)
12 - Activate Backup Image
13 - Password Recovery Procedure
14 - Reformat the file system
15 - Upload a file through XMODEM
16 - Download a file through XMODEM
17 - Start Diagnostics Application
Q - Quit from operational code StartupSelect option : 9
Erasing /dev/dev
mtd0
mtd1
mtd2
mtd3
mtd4
mtd5
mtd6. Please wait..
Erase finished
Boot MenuOptions available
Q - Quit from operational code StartupSelect option : 16
Select Mode of Transfer (Press X/Y/Z for XMODEM/YMODEM/ZMODEM) []:z
Do you want to continue? Press(Y/N): y
Ready to receive file via ZMODEM
Please start ZMODEM sender before the receiver times out
rz waiting to receive.**B0100000023be50
Copy to image1 or image2 chioce(1 or 2): 2
Copying the file. Please wait..
done.
Critical components modified -- System Reboot Recommended!Reboot? (Y/N): y
Rebooting...
Rebooting system!
Sent SIGTERM to all processes
Initializing Arena.
PCI[1]: Disabled
3613652 bytes
Options available
Q - Quit from operational code StartupSelect option : 12
Image /dev/dev mtd0 mtd1 mtd2 mtd3 mtd4 mtd5 mtd6 activated./dev/dev
mtd0
mtd1
mtd2
mtd3
mtd4
mtd5
mtd6 activated -- system reboot recommended!Reboot? (Y/N): y
Rebooting...
Rebooting system!
Sent SIGKILL toInitializing Arena.
PCI[1]: Disabled
3613652 bytes
Exploding tgz file to RAM.../mnt/applicationStarting operational code application...
<10> Jan 1 00:00:32 0.0.0.0-1 General[46401964]: bootos.c(186) 3 %% Event(0xaaaaaaaa)
started!(Unit 1)>
User:admin
Password:
(M4100-D12G) >enable(M4100-D12G) #show bootvar
Image Descriptions
image1 : test
image2 :
Images currently available on Flash---- ---------- ---------- ----------------- -----------------
---- ---------- ---------- ----------------- -----------------1 10.0.2.30 10.0.2.30 image1 image1
(M4100-D12G) #
The error message 'Invalid image name -' is still there nor am I able to boot on image2.
Am I missing something?
- tammtammOct 10, 2019Aspirant
