chfascik
May 05, 2016Tutor
M4100-D12G temperature
Hi, I've M4100-D12G switch and have a question about System temperature. Switch is inside rack cabinet (4U) and System temperature is 47-52C. Cabinet is located in one of my office room. Is this ...
JohnRo
May 05, 2016NETGEAR Employee Retired
Hello chfascik,
Welcome to the community!
I would say it is a little hot but not to the extent of being alarming. Make sure that the temperature of the environment is 0 degrees to 50 degrees Celcius. Check if all of the fans are active as well, monitor the switch and see if the temperature increases.
Thanks,
chfascik
May 09, 2016Tutor
JohnRo - thanks for reply.
M4100-D12G doesn't have fan so it can't be cool down by air. I tried made same rack mode and add dedicated fans to rack case. So now it's quit well. Temperature is 40-45C.
Thanks for help.
