frank_rizzo
Oct 27, 2015Follower
M4100-D12G vlan 1 half duplex
I am in the process of setting up a new M4100-D12G switch. This is my first time configuring a Netgear switch so hopefull this is not a PEBCAK issue.
VLAN 1 is configured for routing and for unknown reasons is running at 10mb half-duplex. I have created other VLAN interfaces with the same result.
How do I configure the VLAN routed interfaces for 1G full-duplex.
(M4100-D12G) #show version
Switch: 1
System Description............................. M4100-D12G ProSafe 12-port Gigabit L2+ Intelligent Edge Desktop Managed Switch, 10.0.2.13, B1.0.1.1
Machine Model.................................. M4100-D12G
Serial Number.................................. 0000000000000
Burned In MAC Address.......................... AA:BB:CC:DD:EE:FF
Software Version............................... 10.0.2.13
Bootcode Version............................... B1.0.1.1
Supported Java Plugin Version.................. 1.6
Current Time................................... Oct 27 12:35:19 2015 (UTC-4:00)
Current SNTP Sync Status....................... Success
(M4100-D12G) #show port status vlan 1
Media STP Physical Physical Link Loop Partner Flow
Intf Type Mode Mode Status Status Status Control
vlan 1 10TX - 10 Half 10T Half Up Off
1 Reply
- DaneANETGEAR Employee Retired
Hi frank_rizzo,
Welcome to the community! :smileyhappy:
Based from the screenshot you have provided, I believe this is just normal. Since its a virtual interface, there is nothing to worry about it.
DaneA
NETGEAR Community Team
