Nighthawk Pro Gaming
5 Topicsinternet not connected XR1000
ik probeer de XR1000 te installeren. Als een extra router binnen bestaand netwerk. deze XR1000 staat op zolder en is met data kabel verbonden aan een ZYXEL EX5601-T1 die benenden staat. Nu heeft de data kabel internet, maar als ik deze in de XR1000 connect en de setup doorga krijg ik volgende melding internet not connected... via pc en mobiel geprobeerd maar geen idee wat ik kan doen. Deze XR1000 zal met mij op installaties gaan voor werk om lokale netwerken te maken tussen verschillende hardware, QUESTS VR, iPad & PC. Dus het is noodzakelijk dat het plug & play is als ik ergens anders lan connect. So i have a local network and want to add the XR1000 to this network. Reasoning is that i generally use the system for projects and have used netgear spiders before. So generally what we did was set the router up as a network that only we can access and once at location connect this to a data cable on site. The system works straight away, and all our hardware is connected to the same wifi and or hardlined. No i'm prepping this XR1000 at home within my existing network but i can't even get internet to work. I get internet not connected even though testing the data cable it's all connected to the internet. It is connected to a ZYXCEL router. So that might be the issue, but based on previous experiences this was never an issue therefor purchasing the XR1000. the router is showing a solid white led on the XR1000.XR500. Horrible online gameplay. More lagg then opponents.
XR500 V2.3.2.114. Amsterdam , Netherlands. Dear Community members, First off all, I'm Dutch so English is not my language but I will try to make myself clear. I've got a lagg or latency problem for years now and I dont know what to do anymore about this problem. When I play Fifa online I always have lagg en totally unresponsive players but most of the time my opponents dont have that problem. Last week I contacted 5 players after a game and they all said It played very well but for me it was unplayable, horrible delay players just dont move as if Ea gives me 2 seconds delay. I tried everything on my router but its just horrible. On my xr500 router and geofilter I can see my ping during the match and it is almost always good ( lower than 20 ms) I have upnp on it it will open only 1 port for Fifa. Is dat the way to go and can that cause problems? That there ar not enough ports opened? The ps5 says that the nat type is 2. By qos I have my PS5 tot priority en bufferbloat to 75%. I'm not a specialist but there is something really wrong otherwise other players would have the same delay but in most cases its not. I even can see their players moving faster than mine. I noticed when I play a game that sometimes the tick rate of the host is higher than the tick rate of the client. Can that be a problem? Who is the client, is that me or my opponent? In the attachment you can see what my router showed. I hope you can help me because Im looking for a solution for really long now and I just want to play an online game where both players will have the same gameplay. Thanks in advanceWel verbinding geen internet, alleen op de 2,4 gHz
Ik heb thuis een XR1000 pro gaming router het gebeurt regelmatig dat ik op 2,4 gHz volledige verbindingssterkte heb maar geen internet op 5 gHz is internet dan nog steeds wel beschikbaar Het lijkt er dus op dat aan de WAN zijde alles okee is ik heb diverse WLAN kanalen geprobeerd .. niet erg logisch als de verbindingssterkte ok lijkt .. maar je probeert wat Verbindingssterkte is super dus het draadloze signaal lijkt ook goed Dat er dan geen data overheen gaat is wat vreemd .. lijkt dan meer iets met routing / firmware / vlan Ik heb zoveel mogelijk standaard ingesteld gelaten iemand een suggestie?Kan mijn Netgear Nighthawk RX500 niet registreren op mijn account
Hallo, Ik heb de Netgear Nighthawk RX500 nieuw gekocht op coolblue.nl. Ik wil mijn Netgear Nighthawk RX500 registreren op mijn Netgear account, maar het geeft aan dat het al geregistreerd is op een ander account. Hoe kan dit en kan iemand mij hierbij helpen?
