Qos
26 TopicsCannot get network prioritisation to work properly (XR500)
Hi everyone, I recently bought a XR500 Nighthawk gaming router. I cannot however get the network traffic prioritisation to work properly. Sometimes it picks up game traffic (Blizzard launcher) but then it turns off when actually playing a game (World of Warcraft). Some games it doesn't even pick up at all (Battlefield 1, 2 & 3; Call of Duty: WWII). I've tried automatic by enabling the "DumaOS Classified Games" option via the associated checkbox. I've also tried adding devices/profiles but that doesn't seem to work either. I've also tried manually entering ports, but get an error message saying that they overlap with another profile. There are some prioritised packets but hardly any at all (~150 out of ~500k). I've also applied anti-bufferbloat and capped it at 75% for both upload and download. As far as bandwidth allocation goes, that's also at 75% for upload and download for my PC and 25% for upload and download assigned to my smartphone. I also have the geo-filter enabled, based in the UK and set to 1400km in filter mode (profile is for Call of Duty). My current setup network wise is I have a BT home hub 5 (an awful piece of equipment I know) setup as an access point. I have the XR500 WAN port connected to the BT router via a LAN socket. This setup will change in the future though when HyperOptic get back to me about why my 1Gbit/s fibre only has a download speed of 5Mbit/s. When that's sorted I'll put the HyperOptic router in modem mode and use that instead. Any help is much appreciated! If you need any more information then please feel free to ask. Thanks in advance!8.5KViews0likes34CommentsQoS not working
When I had a 100/10 cable Internet connection, I used the QoS feature to keep buffer bloat to a minimum. I upgraded to a fiber 300/300 connection today, and when I set the QoS to 300/300, I get about half that speed and buffer bloat is still there. I updated the firmware. It didn't fix the problem. Can this router not QoS a connection this fast?SolvedQOS not showing C3000
Hello I'm trying to enable qos on my router/modem. It is the C3000-100NAS. I believe I have the most current firmware on it. (2.02.17). It also has netgear Genie on it. From what I've found on the internet it seems I'm supposed to go to Advanced -> setup - > and then QOS setup should be under there. But it's not there. I've also tried looking underneath other tabs. Thank you for the help.1.2KViews0likes1CommentA Plea to Developers: Traffic Shaping, QoS, & Bufferbloat Handling
As of today (firmware v. 2.1.2.18), the QoS page in the configuration utility remains opaque, with only a Speedtest app available to tell me what my upload & download speeds look like. For me, with the Orbi doing the routing, & the upstream modem in bridging mode, bufferbloat remains a problem. I suspect many other Orbi users see the same thing: http://www.dslreports.com/speedtest. Other manufacturers address this in their home/SOHO market routers; I suspect under the hood they're using something like codel/fq_codel. It's not rocket science. Netgear needs to address this in the Orbi. If it doesn't, it will drive its customers into the arms of its competitors.R8000 QOS Performance Optimization Database Not Updating
Hello, Whenever I try to update the Performance Optimization Database in the QoS, it says that it hasn't been updated, despite it from the end of 2015 (version 1.80,1.0.26 from 12/28/2015). My router has the most recent firmware update available, as shown in the picture. I had it set to automatically update before, so I didn't think about it too much. I updated my parents' R7000 to a newer firmware, and after I checked their QoS settings. They already had a newer version on the database, and when I hit the update button, their router was offered and even newer version (unfortunately, I don't have that version date or number notated). I started to research my issue when I came accross another thread about the same thing ( https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000-QOS-how-do-you-set-new-applications/m-p/1244609#M51975 ) and the official response from ElaineM was that "We will be providing regular updates on the QoS database on our routers with Dynamic QoS" and "We will inform the community if it becomes available" on April 6th. I can't find any more recent info on this problem. Is the R8000 getting any more QoS Performance Optimization Database updates? Why is it currently not pulling down the current updates? When can we expect a solution to this issue? I love this router to an unreasonable degree (it helped me fix most of my network issues, has amazing Wi-Fi range, and very rarely needs any tinkering or reboots if any issues do arise), and would like to keep all aspects of it updated. Thank you for your help.Solved21KViews4likes30CommentsORBI RBR50 / QoS
Hi folks - bear with me if this is a duplicate, the search I did helped but did not isolate within forum. I am on firmware 1.12.0.18 - after installing manually. That was not fun as it was just out of the box and I was not quite ready for messing about. Anyway I headed over to QoS and in essence found it empty - speed test might be useful but not as the sole QoS entry. I want to QoS by device and by service (as my kids hog bandwidth whilst I am movie streaming or video conferencing) and that is one of the reasons I went for Orbi instead of other Whole Home systems - you know the more admin type functions that are advertised So simply put ... where will these be available please, otherwise I may as well use a cheaper solution that also does not have this function. Thank you - any input appreciatedC7100V - No QOS settings feature ?
The new C7100V does not have the QOS feature to prioritize / depriortize certain devices. Comcast provides an upload of only 10MB in my area and I want to be able to deprioritze the traffic from my cameras to the cloud.. but I cannot and as a result I suffer from regular disconnections / slowness of my phone calls or my internet connection on my main PC. Requesting Netgear to get the QOS feature which has been there on all my previous Netgear routers.2KViews0likes1CommentEnable Upstream QoS (Optimized for Gaming) - "Qos bandwidth of Mbps should be 1 to undefined." error
Does anyone else have trouble trying to modify the "Enable Upstream QoS (Optimized for Gaming)" value from the QOS_main.htm page? It defaults to 512Kbps...which seems pretty low. If i change it to any value of Mbps i get an "Qos bandwidth of Mbps should be 1 to undefined." error. Thanks.n600 c3700-100NAS: Q0S or not?
I use this for home office wifi, and it was purchased specifically to replace the cable company's modem that I had paying to lease (Spectrum, formerly Time Warner). Generally speaking, it has performed well. I use Verizon's 'wifi calling' feature with my Samsung Galaxy S7 so that my calls process via the much stronger wifi network vs. the weak Verizon network service in this area. But recently I've determined that text messages sent to me by others sometimes do not arrive on my phone, and it *only happens when phone is in range of my Netgear router*. (That is, text nondelivery only happens when I'm at the home office. We've tested text on premises with the router operating and then when it's been turned off, and we've witnessed texts not arriving *only* when my Netgear is broadcasting.) I've been told that my router's QoS setting may be a factor... apparently, QoS sets which channels get priority or whatnot? Even though this router is relatively new and I presumed it was a higher quality model with more than just a rudimentary feature set, I can find no QoS setting. Can someone either describe how to find/adjust this setting on my modem and/or describe a workround that will enable texts to reach me while I'm at the home office? (Verizon service is so spotty here that doing without the device's 'wifi calling' advantage isn't an option.)3.3KViews0likes1Comment
