Qos
15 TopicsCannot get network prioritisation to work properly (XR500)
Hi everyone, I recently bought a XR500 Nighthawk gaming router. I cannot however get the network traffic prioritisation to work properly. Sometimes it picks up game traffic (Blizzard launcher) but then it turns off when actually playing a game (World of Warcraft). Some games it doesn't even pick up at all (Battlefield 1, 2 & 3; Call of Duty: WWII). I've tried automatic by enabling the "DumaOS Classified Games" option via the associated checkbox. I've also tried adding devices/profiles but that doesn't seem to work either. I've also tried manually entering ports, but get an error message saying that they overlap with another profile. There are some prioritised packets but hardly any at all (~150 out of ~500k). I've also applied anti-bufferbloat and capped it at 75% for both upload and download. As far as bandwidth allocation goes, that's also at 75% for upload and download for my PC and 25% for upload and download assigned to my smartphone. I also have the geo-filter enabled, based in the UK and set to 1400km in filter mode (profile is for Call of Duty). My current setup network wise is I have a BT home hub 5 (an awful piece of equipment I know) setup as an access point. I have the XR500 WAN port connected to the BT router via a LAN socket. This setup will change in the future though when HyperOptic get back to me about why my 1Gbit/s fibre only has a download speed of 5Mbit/s. When that's sorted I'll put the HyperOptic router in modem mode and use that instead. Any help is much appreciated! If you need any more information then please feel free to ask. Thanks in advance!8.5KViews0likes34CommentsQoS not working
When I had a 100/10 cable Internet connection, I used the QoS feature to keep buffer bloat to a minimum. I upgraded to a fiber 300/300 connection today, and when I set the QoS to 300/300, I get about half that speed and buffer bloat is still there. I updated the firmware. It didn't fix the problem. Can this router not QoS a connection this fast?SolvedR8000 QOS Performance Optimization Database Not Updating
Hello, Whenever I try to update the Performance Optimization Database in the QoS, it says that it hasn't been updated, despite it from the end of 2015 (version 1.80,1.0.26 from 12/28/2015). My router has the most recent firmware update available, as shown in the picture. I had it set to automatically update before, so I didn't think about it too much. I updated my parents' R7000 to a newer firmware, and after I checked their QoS settings. They already had a newer version on the database, and when I hit the update button, their router was offered and even newer version (unfortunately, I don't have that version date or number notated). I started to research my issue when I came accross another thread about the same thing ( https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R8000-QOS-how-do-you-set-new-applications/m-p/1244609#M51975 ) and the official response from ElaineM was that "We will be providing regular updates on the QoS database on our routers with Dynamic QoS" and "We will inform the community if it becomes available" on April 6th. I can't find any more recent info on this problem. Is the R8000 getting any more QoS Performance Optimization Database updates? Why is it currently not pulling down the current updates? When can we expect a solution to this issue? I love this router to an unreasonable degree (it helped me fix most of my network issues, has amazing Wi-Fi range, and very rarely needs any tinkering or reboots if any issues do arise), and would like to keep all aspects of it updated. Thank you for your help.Solved21KViews4likes30CommentsNightHawk AC1900 Model R7000 Speed test QOS
Using windows 10 firmware is always up to date So i been getting Internet spikes on my gaming console i will oftenly lag out of game but Internet does not go off it comes back on in a couple of Seconds. Been having this issue since 7/21/2017 i was doing a wager match cause i play competitive Call of Duty and i got booted offline twice maybe and more than that so idk if that messed it up or not. I think maybe because of my QOS it is dropping me out cause speeds maybe wrong my plan is 200 download and 12 upload i did the QOS speed test and i got 230+ download and 12 upload is this accurate if i do a speed test on any other web site i don't get even close to those speeds maybe the QOS speed test is wrong and is messing up everything please Let me know i also live stream but i got upload for stream at 2200 so its more than enough nothing is wrong there its been happening ever since i got booted offline DOS? or DDOS idk just need help ASAP. I did reset both modem and Router multiple times hope this is good enought info.Solved5.5KViews0likes2CommentsNighthawk R7000 -- WIRELESS speeds FASTER than wired speeds
Hi this is my first post here and it's a weird one for me. I've been running QoS for a while without issue but it seems like after an update and I'm not sure which one my Ethernet speeds have severely throttled. At first there wasn't a dynamic QoS and I went in and manually set what devices I wanted to have highest priority which was my game consoles since they also serve as multi media devices as well. For some strange reason my downloads are capped at no higher than 10Mbps and I get 100 from my ISP but on wifi it way faster. It wasn't always like this. So after a recent update I seen Dyanmic QoS and said let's try it and my Ethernet download speeds went up to normal like 80 on the console while upload stayed around 5 which is fine. All of a sudden My speeds tanked completely. Now I'm barely getting 10 down and 1 up. Should I just turn off QoS? I reverted back to advanced QoS for now because with dynamic on I couldn't join my brother in a pvp match. With advanced settings I'm able to only problem is my wired speeds get throttled a lot. I'm thinking either I turn QoS off or should I bother downgrading the firmware? I know I probably said too much but I'm just trying to be clear. Hope I was. Thanks for any replies.Solved8.3KViews0likes10CommentsX4 R7500v2 New Firmware Rolls back QoS???
In the last couple of weeks I hit the firmware update button to check for anything new, and it installed 1.0.3.10. I thought cool. Then I went over to QoS and checked for an update there. It was running an update dated June 2016 - I did not however catch the version number. It downloaded an update and after, I checked, and the new version is dated April 2015. What the heck? I keep trying to update, but no joy. I did read some old thread about bad keys in the firmware causing problems with past QoS updates, so all I can guess is perhaps the new firmware had a problem too? Can one of you mods check into this please? I have no idea how to recover the previous 6/16 QoS version. ThanksSolved6.8KViews0likes17CommentsDisappointed with the router as it doesn't have important feature to set bandwidth to scope of ips
WNDR3400v3 Case ID: 27440470 I am really disappointed with the router as it doesn't have important feature to set bandwidth to scope of ips. My previous routers which were 1/4th price of netgear had this feature. As my router is connected to multiple devices laptops/pc/smartphones i need to set bandwidth to smartphones as they usually buffer youtube and youtube on wifi default plays at HD which inturn completes the FUP given by ISP. To avoid such problem i use to set 192.168.1.1 to 192.168.1.5 (which are reserved for laptops/pc)will get full speed 60mbps whereas rest ips which are smartphones gets 256kbps (youtube will play at 360/480p resolution which saves ISP fup. PLEASE TAKE THIS ISSUE IN PRIORITY AND RELEASE A FIRMWARE WITH THIS FEATURE. Or else un willingly i need to buy another router.Solved
