RN204
10 TopicsRN204 - Please remove inactive volumes in order to use the disk
After the automated disk maintainance had ran I found it could no longer be discovered on the net. So I powered down and up my RN204 to find the weird 'resyncing' message on the LCD screen. Took several hours to resync. After that I find no volumes on the NAS and the confusing error message in my RAIDar screen with status message that volume data is rad level 5 and there is 0 MB data. Also a second volume that is new with same message, both in yellow highlight. Wen I log in as Admin I find a 'Please remove inactive volumes in order to use the disk. Disk #1,2,3,4 in order to use the drive' and the disks marked in red instead blue in the picture of the raid.Not shure what caused this, nor how to solve this. Use Readynas 204 with four bays containing identical 6 TB WD60EFRX drives (none of them indicating errors in SMART) in RAID 5 (Xraid) confing on lastest FW (v6.8.0) No clue how to solve this error. Can someone please help me with some advice? Thanks Hans1.2KViews0likes3CommentsUser has been Auto deleted - all data lost
Netgear RN10400 , fw: 6.6.0, 2 x 1TB, RAID 1. User has been Auto deleted - all data lost. Can not acces local user home dir?!? Can someone check this? Or tell me, in which log can I check this. Which log file should I look to see from which IP was launched this operation? How to get data from lost home dir. You can send linux commands ... clipping from the readycloud.log … Mar 27 09:05:21 nas-soha rcbrokerd[2577]: ../common/unregister.h:62 DEBUG:../common/unregister.h:62 Unregister Mar 27 09:05:27 nas-soha rcbrokerd[12023]: ../common/unregister.h:62 DEBUG:../common/unregister.h:62 Unregister … system logs : image below (event is marked) One year it's working fine. Maybe the problem is that it has been previously created a local user with the same e-mail. Local user tino.sosteric exist until yesterday but is now gone with his home folder. Any help will be appreciated. Br, TomiSolved48KViews1like706CommentsRN204 "Failed to Startup" + Power Button/LED Flashes + Act LED Flashes
All of a sudden our RN204 was not available on the Network. Power Button was flashing, the ACT LED was flashings, and all four of the HDD Activity LEDs were on. Front Power Button did not work, only way to remove power was to pull the AC adapter connection in the back. When power is reapplied, the Boot process starts, then after about 12 mins, we see the following two messages: > "Failed to Startup" > Retry Startup" While in this mode/state, RaidAR does not see the device. If we go into Tech Support Mode, we see: > [57110] 0.0.0.0 If all four HDDs are removed and we re-enter Tech Support Mode, we see: > [57110] 192.168.168.168 At any time, we can not use the Web-Based Admin to connect the RN204. We have a lot of data and will need to recover it, so hopefully the data is still intact Anyone see this? Where you able to resolve the problem? Any suggestions that does not involve re-formatting the HDDs.3KViews0likes3CommentsDropbox backup - sync status
Hi to everyone. After the factory default reset of my RN204 I set up the dropbox sync to save all my data. I have 4TB of data with big files (medium size 1 to 4 GB) and it's working but the uploading to dropbox it seems not regulat. My upload speed it's not like the download, but I can't understand if sometimes the upload stops or if it start from the beginning after a NAS reboot. Is there a way to check if the Dropbox service is working and what he is doing?4.6KViews0likes5CommentsSQL server, how to download and which one?
Hi, I want to install SQL Server on ReadyNAS 204 with no internet connection available for the NAS. after downloading it from apps site I receive only one file - mysqlr6_1.0.1_all.deb (about 40 kb). Is it normal (I don't want to start installing on NAS, if something might be corrupted). Second question - what version of MySQL is that ? Third question - on App's List on ReadyNAS 204 (OS 6.6.0) mentioning about PostgreSQL 9.1, but it is not mentioned on App's web site, why?Readynas 204 reboot message phy_ethtools_set_wol+4
Hi, I hope someone can help. I select Restart in my ReadyNas control panel to try to refresh my DLNA cache to pick up some new items which hadn't appeared. After rebooting, the RN204 was not accessible on the network and it had the message phy_ethtools_set_wol+4 on its front screen. I left it about 20 minutes but nothing happened and it didn't come back so I powered it off and back on again and the same message has appeared on the front screen phy_ethtools_set_wol+4. I am unable to access the RN204 via the network and don't know what to do. I can't find any reference to this code in the forums or on the internet. Does anyone know what this means and how I can get the ReadyNas working again as I am worried about my data. Thanks RobSolved4.3KViews0likes14CommentsTOSHIBA X300 HDWE160XZSTA 6TB HDD
Has anyone used these toshiba drives in their RN product? Looking to expand the capactity of my current XRaid setup and these have hit a pretty good price point. Would prefer to not be the guinnea pig though! I'm running the latest 6.5.1 OS that was just released recently. Thanks, -MattCan I use ReadyNas as a hard drive for my lightroom 6?
I have a computer I built with running Windows 10 PRO. I only have a 240GB SSD for my hard drive. What I want know is can I also use the RN204 for my Network backup and also use it to work from Lightroom 6 for my photography? I have tried to get it too work but no luck. I currently have it set up with ethernet cables connected to my Netgear AC1750 Wi-Fi router. Do I need to run a USB 3 cord from my computer to the RN204? I used to use my old WD backup drive to work from until it died and I lost all my pictures. So I decided to get the RN204 and put 2 network WD 2 TB drives in it. Can someone help me with this? Craig2.8KViews0likes1CommentPiwigo + RN 204
Hallo, leider war ich der Versuchung der "zu Verfügung stehenden Apps" erlegen und habe Piwigo installiert. Da es jedoch nicht zum Laufen zu bringen ist (zumindest ich bekome es nicht hin), hatte ich mich entschlossen, es wieder zu deinstallieren. Das klappt wohl allerdings auch nicht vollständig, da hier noch Installation angezeigt wird / ist. Wie kann man das Programm rückstandslos entfernen? Wie ist überhaupt die Politik von Netgear zu den Apps? Werden die Apps gepflegt? Das Alternativprodukt "ReadyNas Photo" will sich auch nicht so wirklich starten lassen und hier wirft sich die Frage auf, welche Sinn ein nicht verwendbarer App Pool hat? :-/ Bis denne Christian3.8KViews0likes7CommentsDifferent size HDDs in RN204
Hi, I have recently bought an RN204 NAS with 2x 3TB HDDs and wanted to expand this (2 bays are empty). Currently it is set up in RAID format (although I'm not sure what setting - X-RAID/RAID5 etc) But I wanted to know if I go and buy 2x 6TB HDDs for example, would that give me a total of 9TB space and would I have to do any tinkering? Thanks in advance!Solved3.1KViews0likes2Comments
