ReadyNAS 102
15 TopicsReadyNas app does not sync properly
I am having an issue with the readycloudapp current version. It will connect remotely to the NAS but will only download some but not all the synced documents. The shared folder link keeps flashing working offline then to syncing. I have tried uninstalling and re-installing. Creating and using a different user. It does not matter. I can open the browser version version and drag and drop files and they appear on the NAS in the remote location. They are also deleted from the remote NAS when i choose to delete them. Not sure what else to check. Any information would be great. I need to get this resolved. Thanks LarryBackup from Android don't keep folders
Hi, I have installed the app on my Android and I am trying to make a full backup of all the multimedia files, the problem is that I have a lot of folders/albums full of photos and videos, which when doing the backup are all mixed in the same destination folder. Is there no way to backup the same folders structure on the NAS? I have a ReadyNas 102 with firmware 6.7.5 and an android mobile with the official app ReadyCLOUD 1.2.11 Thanks to all for the help!3.7KViews0likes1CommentReadynas 102 unit ReadyCloud once again not working. FW 6.5.1 SW: 1.13
First off this is not the first time this has happened. Back when I had support on this unit last year I had to backup my data and do a complete whipe and reset (hour of time as you know) not once, not twice, but three times. The reason? Level 3 tech support has told me "we just arent sure but a reset should clear it right up" .... wow. Device: Readynas 102 2-bay with 1TB Raid 1 config Readycloud: FAIL (desktop, app, web) Admin page via LAN: PASS Apps installed: none 100% factory Ok so for the last year or so, it has been working pretty solid. Every day I get to work and it works I am just impressed that I got another 24 hours out of this thing. That said, I did the latest firmware update and ever since it has had issues connecting. I rebooted (power) to the unit and now once again the desktop software shows it as offline. I logged in and noticed the FW update reset the network from static to DHCP. Well the ports on my router are set for that IP so I set it all back the way it was thinking that was the issue. Again reboobted the unit and it got the IP just as before, but now inside the Readynas Admin page the "cloud" tab says that ready cloud status is "Offline (RED X) Services Offiline" you click the little question mark and I just get a loading logo no information displayed. I was able to get into the device last week via the readycloud web ui, but obviously with it now offline that wont work. I can get into the admin settings page though of course. I have a pretty decent history working in all thing IT (work for LG here in South Korea) and so things like a router FW update were first to come to mind. I made sure I have the newest firmware there too ASUS AC router (AC66U) VPN to the router, and all other things like cctv and media sharing devices are working normally. Even on the LAN the readynas will not connect. I have turned off the service and turned back on, power down for 24 hours, remove the account reboot and login, all are to no resolve. Is my only option to backup everything again and do a complete whipe of the system? At this point the device is nearing 2 years old and I have never ever had so many issues with a NAS in my life. So many other options out there that co-workers are friends use and they all just laugh when I told them I got Netgear... I use to hold Netgear to very high standards but apparently that is slipping. 90 days of customer service all that spent on resets and well over 14 hours of my time trying to keep this thing running. Just frustrated at this point. I do not map drives out of fear of ransomewarre taking down everything. Hence I like the desktop app. I did use FTP on my phone, but I have not used that in a long time as I have OneDrive backup from my phone and then the the Readycloud app backup my OneDrive to the ReadyNAS102 (TheDonBot). I did try and set up FTP again but I can not get it to work. I can VPN to my router, but the ReadyNas does not seem to be available. I could just have a setting wrong though. I do not really want to go back and setup FTP again, I just want the desktop software to work. Really appreciate any idea or feedback. If I should just toss this thing in the recycle and buy something else please let me know, money is not really the issue here I just need to stop walking into meetings with things on a NAS that no longer works and then in a mad scramble to VPN to home, map drives, etc just to get the random stuff requested from guys at work.3.9KViews0likes8CommentsRedirect Default Web Access Not Working 6.5.1
I'm not sure if this is a configuration or an OS issue, but I noticed today that all default or unspecified HTTP traffic to my ReadyNAS 102 is going straight to /admin. (example, http://mydomain/ goes straight to the admin login page while http://mydomain/ShareName redirects correctly.) In the past, I could go to System>Settings>HTTP and choose a default folder/share to direct unspecified HTTP traffic to a specified share/folder. When I try to do this now, I only get "None Selected" as an option in the drop down menu. I've tried changing this in Edge/IE/Firefox/Chrome to make sure this wans't a browser issue. Screen shot of issue Any thoughts?4.4KViews0likes12CommentsReadyNAS 102 and BT Business Hub 5
Hi everyone I moved to BT Business on Monday. I connected my ReadyNAS 102 to it and I can access it ok on my mac via finder and explorer on my windows 10 PC. The problem I'm having is when I access over the net via readycloud.neatgear.com. The device is showing as offline. I disabled the firewall on the BT Business Hub 5 but it still showed as offline. I can log on as admin ok when I connect via IP address directly. Can any one tell me what I need to do? Many thanks in advance.Solved3.9KViews0likes1CommentReadynas 102 adding a second disc
Hi I have a readynas with 2TB disc, im ran out of memory and bought a 2 disc with 3TB. I dont want redundance only expanding the memory so i get one big 5TB partion OR two disc 2TB+3TB. Im had x-raid activated and put in the new disc. Now I only get redundance. What to do now?3KViews0likes1CommentUnresponsive/Slow NAS performance post Anti-Virus + upgrade
Hello all Since upgrading to firmware V6.4.1 and upgrading Ant-virus + to version 2.0.3 I have been suffering extraordinary slow/unresponsive performance from my Ready NAS 102. For example: There have been times when it would not allow me to login to the web GUI. Windows Vista, 7 and 10 explorer progress bars took minutes to load directory structures. I noticed an improvement after rebooting the NAS but this was short lived less than 15 minutes. The 4TB NAS drives are only about 25% full operating in a home environment so has a light duty cycle. The Web GUI says the drives are healthy and are operating in the ~38 degree Celsius. The fan is running about ~800 rpm. No virus have ever been found on these drives. Ani-Virus + is the only application that I run on the NAS other than the default ones. I turned off AFS (Apple File System) as not required. I have cleaned out the dust accumulation from 2 years use but the CPU temperature remained in the mid-high 60 degree Celsius range. I felt this is a little higher than it should be. On a hunch I decided to turn off the Anti-Virus + process. A partly loaded file suddenly and dramatically completed loading and equally importantly the CPU temperature dropped to mid-50s degree Celsius within a few minutes. I then performed some file loading tests using an I5 Lenovo T430 laptop. Test file was an XLS of 1.8GB. Application was pre-loaded. Anti-Virus off 7 seconds CPU temp ~55 degrees C Anti-Virus on 3:52 CPU temp rose to ~66 degrees Celsius during the load. I do not any pre-upgrade load time figures for comparison but load times where acceptable. The conclusion is that there is something seriously wrong with the latest version of Anti-Virus + or the priority assigned to the application. I note that other users are experiencing similar response problems but the little I have read have not done much in the way of quantitative measurements. I am reluctant to turn off Anti-Virus + but see little alternative. How can I roll back the Anti-Virus + application and/or when is a fix coming? Regards DavidBa3.1KViews0likes7CommentsRN10200 backup button doesn't work
Hello everybody, here is my problem:front button "Backup" stopped working. If i manually launch backup from dashboard,everything works well,i have only one backup in the list. If i press the frontal backup button,in the dashboard i can see that readynas receive the command,but nothing happens,no errors and backup doesn't start. I have this problem only this month,5 or 6 weeks ago everything was ok,and i didn't touch anything...no updates,nothing...firmware 6.4.2 Someone can help me? thank you3.7KViews0likes5CommentsReadyNAS 102 + rtorrent + rutorrent
Hi, I have a Netgear ReadyNAS 102 with debian ARM. I am following these instructions to install rtorrent + rutorrent... http://blog.rebootr.nl/rtorrent-rutorrent-netgear-readynas-102/ The NAS has Firmware 6.2.5. I am logging in root using PuTTY from Win10. I have a drama when I get to Step seven: test rtorrent. I'm getting the following... /usr/bin/rtorrent: 1: /usr/bin/rtorrent: Syntax error: word unexpected (expecting ")") What's the syntax error mean? How can I resolve this? In any case, if I just run rtorrent using root@nas:/# rtorrent rotrrent launches, but I get... Using 'epoll' based polling Using 'epoll' based polling Using 'epoll' based polling Could not read resource file: ~/.rtorrent.rc What does 'epoll' based polling mean? If I drop the .rtorrent.rc file created from Step five to /root/rtorrent I don't get that resource file issue. But now when rtorrent launches, I still get the 'epoll' thing and also this... The SCGI socket is bound to a specific network device yet may still pose a security risk, consider using 'scgi_local' What does this mean? How do I resolve? I tried these steps once before, ignored issues, kept on going and it went completely pair shaped. Had to factory reset the NAS, stuffed that up and lost a lot of data Oh well, these things happen. Anyway, if I can over the original hurdle of the Syntax error, I may still have questions when I get further on. But... one step at a time. Cheers, daarsk
