Smart Switch
6 TopicsLimit bandwidth on port - confused
Hi I have a guest house and I've created a vlan for the guests there, using only port number 24. I'd like to limit the bandwidth from that port to 100 Mbps but get confused by instructions in the manual and in the web interface. At one place it says I should define the "Interface Shaping Rate" to a number between 16–16384 (manual) and at the other is says between 1-100 (the web interface). I'm doing something wrong. Can you help me out here?GS108Ev3 Port Trunking
Could someone explain this please: Is trunking available for GS108Ev3 switch? I read specs and datasheet and for 8 ports model it says "Link Aggregation/Port Trunking" - NO and only supported on 16 ports model. But at the same time the switch does support multiple VLANs so my question - How is it possible to support a few VLANs but not a Trunking? If I connect a few GS108Ev3 switches together - would I be able to pass ALL VLANs from switch A to switch B over a SINGLE PORT so all ethernet frames will keep their current VLAN labels intact? (that how "stadard" trunk work works) If the asnwer is "NO" - should I go with GS108T instead?4.4KViews0likes0CommentsFinding a mac address off a device on the switch
What are the steps on how to find out the IP or MAC address of a device that is connected to my switch? For example, if someone walks up and connects their device to a port on my switch, how can I view the device MAC or IP address through the GUI via the IP address?3.6KViews0likes0CommentsNew GS308 switch will not give internet and assigns a weird ip. is this for internet or just network
The new GS308 switch will not give internet access and assigns a weird IP address. Is this for internet or just network PC? The purpose of the switch is to give more ports to connect more devices to the Internet right? I connected a new GS308 from working NETGEAR WiFi router to switch then the device to the switch and there is no internet. I cannot see the switch connected to the network and the switch gives out a weird IP address to the device. There are no labels on the ports of the switch so I guess I can use any port to connect to the switch (I tried the 1st port). Am I connecting it wrong? My set up works fine without the switch.3.6KViews0likes0CommentsHur man kontrollerar problem på switchen?
Jag skulle vilja veta hur man kontrollerar sin switch för att se om den har problem. Jag felsöker ett företags Gmail-problem, och tror att det är ett eventuellt problem i nätverket. Jag har ett enkelt nätverk och switchen är näst på tur för att kontrolleras. Någon feedback skulle uppskattas. Tack.
