We have got your request. just call Netgear Support Number 1-888-366-0222. We will help you to fix your issues
5 TopicsFVS318N Firmware 4.3.3-5 port forwarding for more then one network.
From the menu for WAN USERS I see three options ANY, Single or Address Range. I currently use a range and all works fine. My client wants to add another address that can also access the internal machine. I tell them it has to be either ALL or replace the address range that is there with the new one. Am I correct in this?1.2KViews0likes1CommentRN312 NTFS-formatted external USB drive set mount group permissions
Hi, I am currently trying to change the default mount permissions for an external USB hard drive that is formatted with NTFS. It mounts by default as u=root, g=root but I would like to change this to g=admin. If I umount and mount via the CLI, I can achieve this but I cannot find the config file/script to make this happen automatically/via automount. Can anyone assist? Thanks, Pierre595Views0likes0Comments
