advanced features
147 TopicsSetting country code on EX6150
I am setting up my EX6150 and one thing that annoys me is that I cannot set a country code on the device. It has now defaulted to FR and I am not located in France. This might seem like a small issue but since Apple products checks the wifi country code to say what country it thinks you are in when you set them up and I do a lot of testing it is constantly thinking I am in France. So, anywhere I can change it?11KViews0likes8CommentsAdding an ex7000 to my r7000 with smart connect enabled.
Hi, I am currently using a r7000 with smart connect enabled. I know some of you do not like smart connect, but it works fine here and makes it easy for users. I am about to add an ex7000 and was wondring how it will work with the r7000 with smart connect? If I have to give up smart connect so be it, but I am hoping I do not have to. Does anyone know how I need to go about setting this up correctly?4KViews0likes2CommentsEX7000 with my R7000
Hi, I am hooking up an EX7000 as an extender to my R7000 router. The router is using Smart Connect so 2.4 and 5.0 ghz has the same SSID and the best band is automatically selected for each connected device. I can not see such a setting for the EX7000. Should I just set up both 2.4 and 5 ghz with the same SSID and assume it will work, or will I have to turn off Smart Connect on my R7000?Solved4.2KViews0likes1CommentWN3000RP signal ext
I have the WN3000RP signal extender, that is extending my signal from my main router, which is a Cisco Linksys EA3500. However I have a older Netgear router which is a WGR614v10. I cannot seem to get the netgear and the Cisco linksys router to connect as in repeat or bridge, (unless i am doing something wrong). So I thought I would extender the signal with the extender and tehn connect the Netgear router to the extender as a bridge or repeater. Any advice? Thank you in advance.5.7KViews0likes6CommentsNetgear EX3700-100PES turn wifi signal off
I just bought a Netgear EX3700-100PES Wlan Range Extender and successfully installed it as an access point. I'm having two questions: 1) Can I completely turn off the wifi signal (at night) based on a schedule? 2) Can I completely turn off all the status lights on the Extender? Hope somebody can help.4.4KViews0likes1CommentRouter light problem.
Hi, I have a WN3000rpv3 wifi extender and recently i've been having a problem with the router light not being on at all. I've tried to reset my router as I thought that might be the problem. I have tried to connect the extender a few times but nothing. All the other lights are on so i'm not sure what the problem is. Thank you!WR300Rp
Naught his product after reading reviews! The box stats 'boost your existing wifi & deliver great wireless speed where signal is intermittent or weak' My connect is so week i can't load even a email on my iPad! The device is in good range of the excisti g wifi unit but I'm still only getting about 3.1kbps one day and 400kbps another (these changes can be in a matter of seconds)! I stream a lot of photos and videos via the Internet any advice on how to get a strong And consistent connection speed, is there any setting I could change in the configuration of the extender! Thank you3.2KViews0likes1CommentHow to specify channel as well as SSID
Hi, I use my extender to connect to a wifi network that uses captive portal to login. Near the extender there are 3 APs with the same SSID but different channels. The extender sometimes switches among them, probably depending on signal variations. The problem is that when it switches, I need to login again at the captive portal. Is there a way to specify which SSID AND channel to extend? In this way, the extender would remain always connected to the same AP ... thanks a lot. Davide3.6KViews0likes1CommentWN3000RP and captive portal
I succesfully connected to a wifi that requires login through a captive portal. Each device needs to login. Unfortunately some devices like TVs and Consoles cannot connect this way. I am wondering if there is a way to login once within the extender menu and let all devices access without login. Thanks3.6KViews0likes1Comment
