cable modem
4 Topicsmodem CMD31T not working with Wifi router or ooma
Our current Netgear cable modem CMD31T will not work when connected to a wifi router or ooma VOIP home phone service. The modem seems to only work when connected directly to the PC. I have tried different cables and but only shows flashing orange light, meaning no internet connection. Any help? Thanks1.7KViews0likes4CommentsNETGEAR AC1750 / C6300 wifi cable modem router LAN connectivity problems
HELP ... router has been connected since August without any issues, I bought a new lap top and in net genie on my old laptop (where I am typing this) it shows up and looks connected, I go to my new laptop put the network name and password (it is a protected network) and it states I will need to input more info go to webpage I Get a black and red NETGEAR page saying denied access. I go to netgenie ON THIS LAPTOP and left click go through the whole bit, every tab etc and there is nothing no where that shows access/deny access where I can turn it on or off. I have not logged into net genie since August so something is up. ALL pw's network names/ssids are correct and match. I adced the network on new laptop ... and it is not connecting to the web. HELP. I have no idea about any of this ... (I did do all the ipconfig command prompt things too, to make sure that was not the issue) WHAT DO I DO ... Please if you can instruct me thru the net genie thing that is all I have any knowledge of. I AM SO PISSED OFF so any and all help would be so greatly appreciated you have no idea. THANKS.3.6KViews0likes2Commentsusing cable modem with router as only a bridged wireless device
I bought this unit less than 40 days ago, and now because my home business is not running well on vonnage, I need to switch to comcast voice which requires a new cable modem with a lesser capable wireless router. The question is can you use the AC1900 as a bridged wireless router?3.5KViews0likes1CommentMystery of two C6300 cable modem router with dual band wifi.
I have identical c6300 installed at 2 homes (not next door) with exactly the same setup and configuration. Both c6300 have same type and firmware level Dlink cameras connected using wifi. Wifi setting is 2.4Ghz, broadcast, auto channel selection, speed up to 450Mbps, wpa and wpa2 security selected. One c6300 connects with no problem what so ever. The other devices triy to connect to 2.4Ghz but will drop. I checked and confirmed as well as change passphrase. Devices that cannot connect include ipad 3&4, kindle hdx, win10 laptop with dual band n. Only device that can connect at both site ont the 2.4Ghz is a LG LGMS323 android phone. Comcast at both site. Let me know if I can provide you with additional details. Thanks3.4KViews0likes3Comments
