snmp config
2 TopicsM4350-12X12F SNMP v3 traps configuration
How to configure SNMP v3 Traps on this switch? I have current snmp config: snmp-server sysname "CENSORED-SYSNAME" ! snmp-server user "zabbix-netgear" DefaultWrite auth-sha512-key CENSORED-AUTHKEY priv-aes128-key CENSORED-ENCKEY snmp-server password-strength snmp-server v3-host CENSORED-IP "zabbix-netgear" traps priv acl-trapflags snmp-server enable traps captive-portal snmp-server enable traps mac-notification change ip dvmrp trapflags ip pim-trapflags However snmptrapd says that this user has authentication failure, here is part of the config createUser -e SWITCH_ENGINE_ID zabbix-netgear SHA "CENSORED-AUTHKEY" AES "CENSORED-ENCKEY" Despite having correct engine ID, correct keys switch cannot properly authenticate? I think problem lays in switch itself because sending test trap using snmptrap with same engine ID, auth key and encryption key works fine. Firmware 14.0.4.14170Views0likes1Comment
