upgrade
47 TopicsWAX620 upgrade to 11.8.0.10 reset vlan
Last night I upgraded the firmware on my WAX620 from 10.8.13.2 to 11.8.0.10. Everything went fine except for one thing, the main SSID was configured to use vlan111 and this upgrade process reset it to use vlan1. Since my network was not configured to use vlan1, all traffic was blocked causing it to appear as though the upgrade failed. To fix, I brought up vlan1 on the interface so it could reach the internet and more importantly Insight. Next, I logged into Insight and changed the configuration to use vlan111 as it was originally configured. Hopefully this is just a one-off issue. Wanted to report it in case someone else runs into it.Solved316Views0likes2CommentsHow to Upgrade the CPU and RAM in a ReadyNAS 516
Well I have done it. It seems to be working great. I've ran a few basic tests and you really don't get a idea of the differance without accessing it. you can notice the speed Improvment. Accessing files is much snappyer. The main reason for the Upgrade is more Transcoding capabilities at once uisng PLEX which is installed on it. The Upgrade went easyier then I thought it would. I have lots of pictures to help people out that also want to try this. My RN51500 ReadyNAS I actually got about 6 months ago USED for about half the price of a new one. I got it from a 3rd party seller on Amazon. They did screw up at first and sent me a ReadyData 516. That was worthless to me as it wouldn't allow me to use my HDD's I already had. You can only use one's you get from Netgear with a ReadyData!!! They look the same, they are NOT the same!!! This full upgrade cost me around $300 to do, to bascially make is a ReadyNAS 716. Other then the 10Gigbit port. So onto the show. This will be pretty LONG. Before you start, make sure you BACKUP your NAS. You do have a real Backup right? The Orignal CPU is a i3-3220. The NEW CPU is a E3-1265 V2. This is the exact CPU used in the ReadyNAS 716. So for PLEX transcoding, Very roughly speaking, for a single full-transcode of a video, the following PassMark scores are a good guideline for a requirement: 1080p/10Mbps: 2000 PassMark & 720p/4Mbps: 1500 PassMark. The listing on Amazon for the RN51600 CPU is currantly WRONG. It shows a i3-2120. It's NOT! Netgear lists the correct CPU and pulling my old one shows the correct one also. Here is my ReadyNAS 516 in my small closet that's about in the middle of my house where I keep my Network stuff. There's also a duel fan setup above the door that's temp controlled. It auto runs and stops as needed. The fans are quite and mounted to a wood type vent, which I painted to match the rest of the hall way with the vents going in a up direction. Cool air gets sucked in from the bottom of the door where there's about a 1" gap, and gets blown out the top into the hallway. Currantly there's a APC UPS Pro 500, a Motorola Cable Modem, a Asus Wifi Router. The FREE one form T-Mobile!!! Under that is a ZyXEL GS1910-24 Managed 24-port Gigabit Switch. Both 1 gigabit ports on the NAS as plugged in and Bonded. That's the 2 yellow cables plugged in on the left side of the switch. There's also a Tivo Stream Box there on the right of the switch for my Tivo Roamio OTA. My house I wired up and have Multi-Keystones in al my rooms. I'm using Cat-6 cables from Monoprice. Here is the main things you need. The CPU, which is a E3-1265L V2. This is the same one used in the 716. I got this one from ebay with a buy now price of $275. I made a offer for $200 and he countered with $225. So that is what I paid for the CPU. Pay attention to what you are bidding on!!! There's E3-1265L that you can buy for under $200, but it's not a V2 or a chip that was sold in the marketplace. They are engineering samples whch are not suppose to be sold. You see they're all coming from China! You are talking your chances. The Memory I got from Amazon for $84.99. It's Crucial 16GM Kit. This is Unbuffered ECC UDIMM Server Memory. It's 1.3 Volts. DDR3 at 1600 MHz. This is a closeup Here is a closeup of my new/used CPU I got on ebay for $225. Inten XEON E3-1265L V2 You also need some Thermal Compound Paste for between the CPU and the Cooler. This is Arctic Silver 5 that I got from Amazon. There's enough here to do a whole lot of CPU's!!! It's made of 99.9% pure silver and is not electrically conductive. But this or anyting else can cause issues if you use to much as gets all over everything. This was $7.39 at Amazon. This is used to clean the Heatsink and can also be used to clean the old CPU. You don't want any of the old stuff left on. This works great to clean the junk off. There's also enough to do many CPU's and heatsinks. This was $8.11 on Amazon. Once you have the CPU, the RAM, The Thermal Compound and cleaner, we can start the Upgrade Process. This is my NAS now pulled out of the closet and on the table. You can see I like the label things. My HDD each have a label on it, and because you can't just pull them to look, I also have a label on the side of the case. What kind and size of HDD and when it was Installed. I didn't pop them all in at one. I Installed a HDD as I needed them for less wear and tear. Hopefully doing this I won't have a issue of 2 HD taking a dump at once. The first 4 HDD are WD Red 3TB is size. They were in my ReadyNas NV+ V2 before I got this NAS. The first one installed was on Jan 17th 2013. So it's coming up on almost 4 years now. Here's a closeup of my first NAS HDD almost 4 years ago now. I pulled all my HDD's. You don't have to, but it makes the NAS much lighter to move around and take apart. As they are all labeled, they all will easily go back in where then need to be. Remove the 7 screws on the back of the NAS at the red circles. I learned there was 1 broken off screw o the bottom right. I didn't know that. Not sure why that is? Who wanted to take it a part for whatever reason. Once the 7 screws are removed. You want to slide the cover back about half a inch and then lift up. There is a lip on the top front of the cover and lips on both bottom sides. It's a little snug. I used the flat edge of the screwdriver and sticking it inbetween the bottom bolt locations, carfully pried just a little be on both sides, then pulled back and up and off. This is a right side view of the NAS. You can see the Hard drive slots on the left and the motherboard there on the right/back in this picture. Now you have 2 screws to remove. You see them here in the picture at the red circles. Once Removed the back will pull off. See next picture. You can go ahead and carfully pull off, top off and down carfully where you can reach in and unplug the power connection and the fan connection as shown in the red circles. Here is what it looks like once you remove the back of the case. You can see the HDD board and the motherboard is there on the right. The red circles are the 2 connection points that link the 2 boards togeather. You want to make sure they plug in togeather when you re-Install the motherboard, which does have alignment pins on the motherboard case cover to help you. This is the left side of the NAS. The motherboard side. Remove the 4 screws that are in the red circles. Once done, you can carfully pull this out, starting with the top. There are wired connections on the bottom, watch out, Tilt down from the top, swinging down most of the way where you can reach the wire plugs. Here I am swinging the motherboard down where I can then get access to the wired plugs. Here's a close up. There are 5 different plug connections. One I have removed already. They all only go in one way, except the small 2 wire plug. I just plugged it back in the same way it came out. A couple are locked in and so you need to push t unlock and pull. That's 2 of them, the one I already removed and that large one that has P1 on it. The thers just pull off. Be careful and kind of wiggle off. Here is what the NAS looks like once the motherboard is removed.Converting from Circle box to Circle on Orbi
I’ve been using a Circle Disney box connected to my Orbi router before it became avalaible as part of a recent software upgrade. My question is how do I switch my Circle box over to the Orbi directly? Is it as simple as disconnecting the Circle box and enabling the Circle feature on Orbi? The Circle box has battery backup so I’m concerned about having two instances of Circle running. Will the Circle app automatically recognize the new switch over to the Orbi setup?R7000 after firmware upgrade, Bedtime function in Circle doesn’t function properly anymore.
I have just updated my Netgear R7000 firmware to V1.0.9.26_10.2.31. I have also enabled the Circle(parental guidance) on my Netgear router with bedtime function turned for my kid. After the firmware upgrade, my kid's profile seems acting very strange, such as it immediately said all the time has been all used up and it keeps saying it has been passed his bedtime. I have recreated my kid's user profile from my iPhone Circle application but still, the bedtime isn't working properly. Can someone help, please? Is this firmware not compatible with Circle on my Netgear router?1.9KViews0likes4CommentsUpgrading firmware on ReadyNAS 3200
I have inherited an old ReadyNAS 3200 with firmware version 4.2.22. I want to upgrade it to the newest firmware 4.2.31 but am unsure if there is a step process or if I can just load 4.2.31. This is part of a production network and am unsure about how long this might take to upgrade. The system is also over 80% filled. Any help with this would be appreciated. Thanks.Which firmware version are you running?
I am seeing a lot of threads of some dissatisfied ORBI users and me personally am running the latest v2.1.2.18 on the RBK53 system. I have been fine with all firmware revisions and I am currently running about 40+ devices. These devices consist of MAC’s, PC’s, Printer, PoE Cameras, and WiFi Cameras, Samsung TV’s, a slew of iPad’s, iPhone 7-8, XBOX’s, PlayStations, etc. I have a very healthy list along with older kids doing some heavy gaming and streaming of NetFlix. On average I use about 1TB of bandwidth a month from my ISP. In all, things have been good and I am a geek. I have every Cisco cert there is along with Security and I have been monitoring everything. If someone goes down, I hear it within seconds and I have not heard anything from anyone.....and we are power users. My question for this thread is, What version of firmware are you running? I am tempted to move to the new current version of v2.0.1.4. Since v2.1.x.x and above has been formally placed in ‘No Forced Upgrade’ mode. (See Here for Post) I assume Netgear's confidence in that later version is limited due to all the bugs. But, I am not having any issues - Just being honest. I will also state that I am religious on keeping systems drivers up to date and watching the forums for other devices that are prone to not play well with other WiFi systems. Examples: Killer WiFi cards are junk and I had to upgrade to Intel and now no issues. But – I thought it was ORBI Chromecast EERO devices not playing well, etc. etc. I admit, you have to pay attention and one device on your network could be causing a lot of pain and it may look like it’s the ORBI. Epson Printers not playing well with certain WiFi frequencies Carrier Smart Thermostat not playing well with newer frequency bands causing me to have to plug in a legacy 802.11 access point just for that. It wasn’t ORBI, it was the thermostat and nothing I can do about it. Hikvision WiFi IP Cameras got horrible firmware pushed to them which caused constant drops. I couldn't downgrade so I had to RMA all the cameras for new ones - Again, It wasn't ORBI I am not here to defend either. I have had ASUS w/ Merlin firmware which now has the AIMesh firmware, I have also had the 1st Gen Eero’s which were SLooooow, and now ORBI. They all have their limitations but I consistently I always found a device on my network as the culprit. Yes, if your ORBI reboots every 5-minutes then you definitely have an issue. RMA that thing. And yes, I am sure that the v2.1.x.x is unstable but to what extend and what are the enviroments causing this. (Buffer overflow, bad coding, devices not playing well, User error, etc. etc) But, let us know what firmware you are using.PSU not detected after upgrade to FW 6.9.1
After upgrading to FW version 6.9.1 from 6.8.x i see log messages that indicate PSU1 not detected and PSU2 not detected. The unit is populated with 12 4TB drives. I've attempted to upload the logs but the zip file is not accepted. Furthermore only jpg,gif,png,pdf are the only file types accepted. Am I expected to convert every file contained log download from .log (text) to a pdf?Solved5.6KViews0likes13CommentsReboot ALWAYS fails after firmware upgrade on ReadyNAS RR4312X
Hi, I've just upgraded our NetGear ReadyNAS RR4312X from 6.8.0 to 6.9.1 and actioned a reboot using the webUI after the upgrade. However once again (this happens after every FW upgrade), the system fails to come online again. The system doesn't even respond to PINGs. - We have to power cycle the system after every upgrade to get it back online again. NB: The firmware installs successfully everytime, so it's just the reboots afterwards that are problematic. Not good for remote sites! Any idea's please? P.S. my entered text 'ReadyNAS RR4312X wont save in the 'Model' section of this web support form.2KViews0likes7Comments
