khawe
Apr 06, 2021Tutor
2 Days of trying to connect Orbi - no luck.
Tried Netgear support - no answers. I have been trying for 2 days to get my Orbi to work. I use the app and it says it cant connect to my wifi network - i go through all the trouble shooting - nothing. Power cycle, nothing. New System setup. Nothing.
Any guidance on what to do or where to go before I return this?
What model Orbi do you have?
Try using a wired PC or laptop connected to the router unit and web browser to access orbilogin.com.
- khaweTutor
Model: CBR40|Orbi AC2200 Tri-band WiFi Cable Modem Router
When I goto OrbiLogin.com I get this message:
Looks like you’re not connected to your Orbi’s WiFi network. Don’t worry, it happens to the best of us. Try the following steps to get connected: I try all of those steps and nothing works When I goto the App it says it cant join my network - there is no Orbi network to join. So, there is wifi even when the Orbi is connected but its not connecting to the orbi
You need to be wired to the RBR with a PC or laptop. Not connected wirelessly.
Try a factory reset on the router unit. Press the reset button for 15 seconds then release. Wait for the top ring LED to pulsate WHITE. The try to connect to 192.168.1.1 or .0.1. Go to the bottom of the page and select manual setup.
- Ha_Ku_NaLuminary
khawe wrote:Tried Netgear support - no answers. I have been trying for 2 days to get my Orbi to work. I use the app and it says it cant connect to my wifi network - i go through all the trouble shooting - nothing. Power cycle, nothing. New System setup. Nothing.
Follow the setup guide:
https://kb.netgear.com/31017/How-do-I-set-up-my-Orbi-router-and-satellite
You have not mentioned what exactly is not working.
- vajimMaster
he/she has a modem/router combo I believe....
- Ha_Ku_NaLuminary
Double-NAT is in most cases not an issue. Most routers offer a way to set "static routes".
But this requires a configuration on the "other" (non ORBI) router.
- Ha_Ku_NaLuminary
vajim this is post #8. do you see any fight or interruption here ? I guess something went wrong with your life somewhen in the past.
And this was my comment in post #10 regarding double-NAT:
If you are able to read, I wrote "in most cases" & "most routers offer a way".
And if you reached this line, read also post #12 carefully.
But Iˋm sure you are not able to really read and understand, therefore it is still hard to really help other users here as long you are spamming all the threads here.
