BSmithline
Dec 14, 2017Aspirant
ALERT TO USERS RBR50/RBS50 you may have to do a manual FIRMWARE update
ALERT TO USERS RBR50/RBS50 your systems may not show that a NEW firmware update is advalable when under Advanced / Firmware you choose "CHECK"
I had to do a manuel update. I know that the average user does not even check for updates. It was my hope that these newer devices where going to auto update firmware. Looks like we are now going to have these devices all over the world that will never be updated. What a same.
- guzzijasonApprentice
BSmithline wrote:ALERT TO USERS RBR50/RBS50 your systems may not show that a NEW firmware update is advalable when under Advanced / Firmware you choose "CHECK"
I'm pretty sure this behavior is deliberate. When new firmware is first released, it can only be used for manual updates by "early adopters". Eventually (assuming things go well), Netgear will enable it for automatic updates. In other words, the people doing the early manual updates are essentially acting as testers for the new code before it is switched on for automatic updates for everyone else.
- jvaudioTutor
I updated one of my RBS50 satellites to the lastest firmware manually. When I went to update the other one, the popup fails to load - the dialog just shows the code for the popup. I've disabled ublock origin and allowed popups for orbilogin, but this issue remains. I tried Chrome, Firefox 57, Vivaldi, and Edge.
I was able to update the RBK50 firmware, but now I have one satellite on 2.0.0.74 and one on 2.1.1.12. Does anyone have any ideas or suggestions?
Thank you
- tagteamVirtuoso
BSmithline wrote:
...I had to do a manuel update...You're lucky. I have to wait for the push because Manuel refused to do the update for me.
- netgearguyApprentice
tagteam wrote:
Maybe Manuel needs to get some additional training on routers? Or is he just too recalcitrant? FWIW, his brother Manual updated my Orbi just fine. ;-)
- aani75Apprentice
:-) nice one.
There are many users who are not happy that they have updated to 2.1, so as noted it's kind of a no-win situation depending on whether the new FW turns out to be a friend (and you didn't update) or foe (and you did update). :)
- ElyLuminary
LOL Netgear is dammed if they do dammed if they don't, many people on these forums complained because all previous firmware was auto-updating, now they get complains because it doesn't auto-update lmao.
Anyways dude relax, I'm almost certain that the firmware will automatically update at some point in the future the next time the router is rebooted or power cycled, no need for these alarming headlines.
- BSmithlineAspirantThe problem was that the “check” function did not work.
- JMU1998Luminary
Great news ever! Now I don't have to worry about auto update being forced to me breaking my network setup.
- Retired_Member
Do I have to upgrade the firmware if my Orbi is working?
- BSmithlineAspirantSecurity. In this case the version I was running was not updated to patch the "Krack Attack" security hole.
