AmitR
Dec 05, 2017NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
We’re excited to announce that OrbiOS 2.1 is now available for immediate download here:
https://www.netgear.com/support/product/RBK50.aspx#download
https://www.netgear.com/support/product/RBK40.aspx#download
To manually upgrade your Orbi, see the KB article here: https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
This firmware contains several new features that have been eagerly awaited by the community.
- Parental Controls using Circle with Disney
- Ethernet Backhaul, which allows to use Ethernet to connect two Orbi
- Backhaul Status & Quality on the Attached Devices Page
- Other smaller features
- bug fixes
OrbiOS 2.1 will be available through auto-firmware upgrade soon, but if you want to get started on it sooner, feel free to download and install.
Orbi Product Management
- valdisjAspirant
Seems I cannot waste any more time and nerves with this solution. Sending ORBI back. I was not able to establish not stable wireless backhaul, nor ethernet backhaul, and router was often not able to get IP addresses from the main home router. This solution really is full with bugs. :(( I was so much hoping to use its advertised features, but this is just taking 2 hours every day to try to troubleshoot, reconfigure, restart and try and try and not succeeding. Enough. I'm sorry, but Netgear really screwed this up. And this is not ORBIOS 2.1 problem, this is a deeper whole system problem, since even before upgrading to 2.1 I had same issues :(( Very very sad. Do not recommend this solution to anybody.
- kmichalecApprentice
I know this shouldn't be the fix, but for those that tried tp upgrade to FW ver 2.1 and are having these connectivity issues, have you tried to roll back to v1.12.0.18, and if so, does it fix the stability? I'm on v1.12.0.18 right now, and things have been running great. I wouldn't mind helping out with the testing of 2.1, but only if I know that rolling back to ver 1 will at least restore connectivity, if things get to bad.
Otherwise, I'll just patiently wait here on 1.12.
Also, I see there is a version 2.0.0.74 out there. Are there stability issues with that too?
- KMAnandGuide
2.0.0.74 has terrible connectivity issues. 2.1.1.12 just made them worse. I hear the 1.x versions are fairly stable. However, I also hear that they have some major security bugs which were patched in the newer versions. I'd be rather concerned about using 1.x and leaving my home vulnerable to hacking.
- New firmware 2.1.1.16 is released with fixes for no devices shown and high cpu usage in AP mode
I am one of the many having high cpu usage in router mode, is it fixed in only AP mode or both?- dmw_2Guide
I see that they are pushing out 2.1.1.16 as an automatic update
- dmw_2Guide
Although they are now pushing out 2.1.1.16 automatically I have updated my router RBR50 and satellites RBS50 manually. The issue of connected satellites not showing appears to have been resolved. I also updated my RWB30 to 2.1.0.18_1.0.9 manually. Everything seems to be quite stable and has been for a few hours now. However, I decided to try the ethernet backhaul option between my router and one of the satellites ... everything came to a halt and devices failed to respond so I disconnected quickly and after each satelllite rebooted itself things again became stable. Previously I was on 2.0.0.74 and personally I have never experienced the frequent disconnection issues described by others.
- CattleDogAspirant
I applied 2.1.1.16 and it appears to have fixed the issues I was having (its been about 8 hours so far).
- netgearguyApprenticeDoes it fix the intermittent network drops/loss of connectivity?
- webminsterLuminary
Doesn't appear to fix the display of attached devices as advertised... it showed up for 3 hours after the update, now is consistently empty on my satellite. Am certain there are devices connected to the satellite.
- CattleDogAspirant
kmichalec wrote:
CattleDog wrote:I applied 2.1.1.16 and it appears to have fixed the issues I was having (its been about 8 hours so far).
Which issues were you having exactly, and what FW version did you upgrade from?
Loss of connectivity about once every hour or two. Would typically last 5 to 10 minutes. I have two satellites. One disappeared (no longer seen as a connected satellite). The other seemed ok, but suffered the same drop out issue (probably coming from the router).
I was fine and stable on 2.0.0.74 on all 3 devices (RBR50 and 2 RBS50). I manually applied the 2.1.1.12 update to the router and it all went to hell. The satellites would never take .12 manually. After a few days, I rolled the router back to 2.0.0.74, but the issues remained.
I am now on 2.1.1.16 on all 3 devices, and everything is working as expected (I had to manually re-add the one satellite).
Do we know if it will be extended to the OrbiPros - especially the backhaul feature.
Thanks
- dmw_2Guide
Having been a very early adopter of 2.1.1.16 and experiencing a lot of wifi disconnections I decided to wait a day or so before upgrading to the beta software. Just over 24 hours ago I upgraded as follows RBR50 to 2.1.2.10, RBS50 (2) to 2.1.2.10 and RBW30 (1) to 2.1.2.2. Everything seemed rock solid so I decided to try the ethernet backhaul to one of my RBS50 satellites. Within moments of plugging an ethernet cable into one of the LAN ports of the satellite and the other end into a remote switch located near the satellite the network just went into a cycle of crashing, coming back up, crashing etc. I have a number of IP cameras both on the LAN and remote (on iSPY) and they were streaming video, then disconnected, coming back and then disconnecting again. I waited 15 minutes to see if things would settle down but then gave up and disconnected the ethernet cable. After about 5 minutes and a power cycle of the RBR50 things returned to normal. I see from this thread that others seem to be using ethernet backhaul without any issues. I haven't found any instructions saying there is some particular way to connect the RBS50 to the RBR50 via the LAN so can anyone shed any light on what I am doing wrong?
- tagteamVirtuoso
Not sure whether or not it will be of much utility to you, but a Netgear support article on the subject is at the link below.
- Bing-StrollerLuminaryI had similar problems with crashing and random reboots when I tried the ethernet backhaul (between 2 satellites) on a reasonably stable setup.
Appreciate the diagrams - thanks.
But, with no clear guidance on how to get to that stage it's all guess work.
i.e sync everything and then connect or switch on in a particular sequence after connecting.
It's all trial and in my case - error/crash.
- aazVirtuoso
dmw_2 wrote:.. Everything seemed rock solid so I decided to try the ethernet backhaul to one of my RBS50 satellites. Within moments of plugging an ethernet cable into one of the LAN ports of the satellite and the other end into a remote switch located near the satellite the network just went into a cycle of crashing...
What kind of switch do you have connected to the satellite and what plugs into that switch? Do you really need more ports there than the satellite can provide?
Also maybe try using ethernet backhaul through the switch instead of connected directly to the satellite if you can.
- dmw_2Guide
Thank you tagteam for directing me to that diagram about how ethernet backhaul can be set up. I am not sure if it's critical to have the RJ45s plugged into those exact LAN ports but the diagram with the SWITCH best matches my set up. However, with the Orbi coming so long after me laying concealed ethernet cables around my house over time, there are in fact 3 switches involved before the satellite. Within a few inches of the RBR50 there is a Netgear GS308 which primarily serves all the devices round my PC workstation. One of the ports on the GS308 is then hard wired round to a cupboard and a Netgear Pro Safe GS116 (that provides ethernet to various hubs e.g. British Gas HIVE, a weather station, a NAS (Netgear ReadyNAS 212) etc. One of the ports on the GS116 then goes out to the garage and a TP Link PoE switch which connects to several wildlife cameras, IP cameras and micro PC used as a camera server. One of those TP Link ports is where I plugged the RBS50 into. Now, responding to aaz's question ... the garage is right on the limit of backhaul signal and shows as 5G but POOR (probably 25 feet but 3 brick walls away). As the ethernet cable is already in situ I thought it made sense to use that for the backhaul but it cannot be used exclusively by the RBS50. It's possible I could plug the ethernet cable from the GS116 into the garage into the RBS50 and then put the TP Link switch beyond it (thus reducing to 2 switches between the RBR50 and RBS50) but whether that would solve my crashing network problem I do not know without trying. I hope my explanation of my network topology makes sense.
