AmitR
Jan 17, 2018NETGEAR Employee Retired
Announcing availability of OrbiOS 2.1
I posted this on a different thread, but copy & pasting it here for more visibility.
Let me give you a quick update on where NETGEAR is with the OrbiOS.
Just before Christmas break, we paused the distribution of OrbiOS 2.1. Very soon, we're about to restart the distribution of a slightly updated version of the beta (2.1.2). In addition to the major new features introduced in 2.1 (e.g. Circle, Ethernet Backhaul), this firmware is expected to address the high CPU issue, as well as the special character in PSK issue as well as support for the Outdoor Orbi. Check Release Notes for complete list.
We are continuing to work on the issues with Google devices that have been documented in the press (several users have provided links here).
My recommendation is that you should either use the Orbi Mobile App (if you haven't seen it recently, check it out, we've made some major improvements) or the Web UI to check for new firmware or wait until your system gets auto-upgraded.
Link to RBK50 firmware & Rel Notes: https://kb.netgear.com/000053549/RBR50-RBS50-Firmware-Version-2-1-2-18
Orbi Product Management
- MrX911Apprentice
Updated. 3 reboots within the first 2 hours
- bmcguirkInitiateWhere do you go to check whether the router or satellites have rebooted? Or check CPU utilization?
Ever since installing 2.1.1 .12 and 2.1.1.16 I had been experiencing WiFi dropouts. (Laptops falling off WiFi, mobile phones that rely on WiFi for calling dropping calls, FaceTime calls having multiple pauses/poor connection messages) multiple times per day. Seemed more like wireless radios on Router or Satellites toggling off and on rather than rebooting. Seeing the indication that CPU being high makes me wonder if that was the cause of the Devices falling off the WiFi for a few moments.
I installed 2.1.2.18 two hours ago and so far things have been stable. FaceTime calls are much better. Time will tell.- guzzijasonApprentice
You can get uptime and utilization for the router or satellites by going to:
https://[router-or-sat-ip-address]/debug.htm
- Took update now nothing will work tried several reboots and nothing . How can I roll back to stable release?
- tagteamVirtuoso
You simply download the previous release (of your choice) and then do a manual update, ensuring you update the satellite(s) first. However, unless you disable auto-updates as set forth in the thread below (Message #105), you will ultimately be updated to the current release.
https://community.netgear.com/t5/Orbi/Firmware-V1-12-0-18-Discussion/td-p/1320421/page/5
update: I rebooted the router and satellite with 2.1.2.18 this morning. knock on wood, everything is now running fine now. Hope it stays that way.
- ElyLuminary
Mine updated automatically, however the satellite did not update and it stayed on the older firmware, I had to re-install the older one on the router again, then manually update the Sat first and then the router, so far so good for the last few hours.
Netgear what on earth is happening with the latest update? We can no longer access the internet! The router is in constant red hue now! Even after power cycle it won't re-establish internet connection. Why bother sending out and update and break all of our routers? When things are performing so well.
Running on PPPoE, no way to reestablish Internet at all. This is ridiculous! Check the thread of complaints, get your act together. We didn't pay a premium for **bleep**ty QA and software testing!
- Dustin278Apprentice
xanderwong wrote:Netgear what on earth is happening with the latest update? We can no longer access the internet! The router is in constant red hue now! Even after power cycle it won't re-establish internet connection. Why bother sending out and update and break all of our routers? When things are performing so well.
Try and restart your modem - works everytime for me
FYI - I have been up and running for 12+ hours on the 2.1.2.18 without problems coming from 2.1.1.16 without any problems..
- ktdApprentice
2.1.2.10 worked really good for more than a week and so far 2.1.2.18 is working just as good.
I think we finally are heading in the right direction now.
One RBR50, two RBS50 and no Android devices.
The beta that was out has been very stable for me and this release has been equally solid so far. Hopefully we are back to the stability I experienced throughout my Orbi ownership outside of the December nightmare.
- Anonymous
I'm actually wondering what is considered to be 'high' CPU usage? My router is somewhere between 2% and 7% which given the load looks totally fine to me. The sat is hovering between 15% and 33% with only a printer attached that is actually in sleep mode and a good backhaul connection. Are those normal percentages? I not worried at all - my Orbi system has been running fine since I first got it roughly a year ago - but am just curious.
- 4boysGuide
Updated to 2.1.2.18 on Wednesday and have been running without issues. Can't comment about Android devices but I have 24 devices (including August products) attached to my RB50 setup with 2 satellites.
Everything solid here. No google/android devices (excpet my wired samsung tv). ~90 devices depending on who's home. RBR50 router, 2 RBS50's and 1 RBW30 satelites.
2.1.2.10 and now .18 have been the best FW for me since I purchased back in November!
- timchLuminary
Just checked my system. The router CPU is 7% and the satellite is 11%. The system has been up for 2 days and 12 hours ever since I updated to .18 and appears to be rock solid. I am running the Orbi in AP mode and have a mixed environment of apple, Samsung, google Chromecast, Nest, Sonos and echo dots.
whilst I recognise that some people are clearly having difficulties, my system has worked perfectly now for months and I’m actually impressed so far with Netgear’s responsiveness both on here and with regular updates.
As as I would like another system for my parents, I have been checking eBay but no sign of a mass exodus so my conclusion is that the problems reflected here are not as widespread as reading the posts might imply; of course doesn’t make it any less frustrating for those who are having difficulties.
- BobDukeApprentice
2.1.1.16 was working well for several weeks, with known cosmetic issues.
2.1.2.18 was installed using the Update All button without any issues.
All has been well in Orbi land for the last couple of days.
I know it's not critical, but I do enjoy seeing which Orbi each device is connected to. Just wish we could sort the list of devices as we can in the Orbi app.
Two floors x 1200 square foot house. Orbi at opposite corners of house, one on each floor.
Devices: Windows 7, Android, Roku, WDTV, Samsung Smart TV.
- yaggermrGuide
Getting constant network loss. Now I also lose my Lan connection as well as WIFI. Guess I am rolling back to 2.0.0.74. Getting close to bagging this Router. It's just way to unstable.
- webminsterLuminary
Despite having gone through the telnet autoupdate-disable instructions carefully back on 2.0.0.76 a while back, my router and satellite auto-updated overnight to 2.1.2.18. My LG TV did not connect on power-on this morning, which I saw happen often on 2.1.2.10 as well. Never that problem with 2.0.x.
Will be testing for the apparent packet loss issue I've had previously with 2.1.x later today.
I really hate that I can't reliably control if the box updates. I really want to like this, but a device that refuses any role for the user to manage the device realy doesn't have a place in my home...
- EvelineAspirantHello, I have one satellite that updated to new firmware and one that did not...what can I do? Thanks
- LHZGuide
Is it just me or has AC and N mode somewhow being disabled after this upgrade to V2.1.2.18?
I get horrible throughput with speedtest.net from any orbi connected device. eg. 13Mb/s.
When I look in "inSSIDer" app - it shows Max Rate of 54Mbs.
If I test from the orbi itself I get the expected 115Mb/s.
Any ideas? I made no changes other than firmware upgrade.
LHZ wrote:Is it just me or has AC and N mode somewhow being disabled after this upgrade to V2.1.2.18?
AC is working fine for me on V2.1.2.18.
One thing to check: make sure you have WMM still enabled in Advanced WiFi settings. Disabling WMM will automatically disable support for AC/N modes.- LHZGuidethx for quick reply - that was indeed the case. enabled WMM and back to AC/N. weird that it was working for me before.
- OrbiDemigodApprenticeInitially when I bought this router in June 2017, it worked flawlessly for the next 4-5 months without any issues. I praised this router as the best I ever owned.
Fast forward to a month or two ago, firmware updated automatically and the router started crashing once or twice a day for no reason.
Now since last month this router has been crashing 5-10x a day.
How do you guys release firmware that can't even make this router function as a router, it's sole purpose??????????????????
But then add a feature (Disney Circle) that most of us could care less about, that probably is part of the problem.
Is it that hard to release a solid stable firmware that makes our router start working again?
Is it really that hard? - linkwrtGuide
Just installed here in europe.
No issue until now.
Wireless/ LAN voip /netflix is working.
