jmchez
Mar 15, 2017Tutor
Any Plans for ORBI Firmware Upgrade for guests on WiFi to see each other WITHOUT accessing the LAN?
Are there plans for a firmware upgrade to the RBR50 firmware to allow guest to see ach other wihtout having acess to the main Lan?
If the answer is no because this is a limitation of the product, I will start to see how to recoup my $300 dollars and sell the ORBI set. I hope that it doesn't come to that.
jmchez wrote:Are there plans for a firmware upgrade to the RBR50 firmware to allow guest to see ach other wihtout having acess to the main Lan?
this actually doesnt make sense as you wouldnt want guest access to the lan or each other , the whole concept of guest isolation and guest wifi is built on this in most domestic wifi
in more soho / prosumer type gear you can use vlan and do what ever you want but this features is found on a different class of gear
The Velop also has the same restriction.
- DarrenMSr. NETGEAR Moderator
Hello Jmchez
Can you be a little more specific what you are wanting to do with the guest network?
DarrenM
