IamMightyThor's avatar
Jun 01, 2017
Blocked Sites/Keywords on Guest Network
When you set up blocked sites/keywords, does that also block them on the guest network?
Also, when you add a trusted IP, does the router cache that IP? If so, how do you clear that cache?
I blocked a site at the router, but can still get to it from teh guest network.
  • FURRYe38's avatar
    Usually since Guest Networks is tied directly to the WAN side, blocking of certain web sites and places isn't a feature of some home routers.
    • IamMightyThor's avatar
      IamMightyThor
      Guide
      someone on the guest network can then still do illegal things and cause you pain with your ISP and other entities.
      Not Good!!!
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello IamMightythor
    I will have to check on that and report it as a issue.
    DarrenM
